![]() | #46 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001 Location: Where dreams become reality. Age: 55
Member: 4042 Status: Offline Thanks Meter: 24,046 | UFSx+HWK Release 21/08/2013 WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. You need to uninstall old HWK Setup Suite and HWK Support Suite and use the new UFSx Support Suite. DCTxBB5 v2.3.0.1 ----------------- 1. Updated UFS Drivers Support. LG_GSM v2.3.0.1 ----------------- 1. Infineon Bug fixed (present in V 2.3.0.0) 2. Added access to UFST [PWR-R/T] Port (UART Rx,Tx) SAMs v2.3.0.1 -------------- SWIFT-AEROFONE C3262,S3332,S3570,S3572 added (UNL,SECT,IM,FL) SWIFT-3G A157 IMEI Rebuild fixed. INFINEON Infineon Bug fixed (present in V 2.3.0.0) S3800W added (CUNL,PUNL,PIM,FL,UFL) COMMON Fixed "UFSx Devices not Found" on USB 3.0 Host Controller. SeDBx v2.3.0.1 -------------- 1. Updated UFS Drivers Support. Many thanks to all those who have supported us!!! Official SarasSoft Mirrors:- http://forum.gsmhosting.com/vbb/f311...tions-1216246/ Last edited by Odia The Ultimate; 08-21-2013 at 10:52. |
The Following 14 Users Say Thank You to Odia The Ultimate For This Useful Post: |
![]() | #47 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,056 | UFSx+HWK_UFST Release 28/10/2013 Release 28/10/2013 WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. You need to uninstall old HWK Setup Suite and HWK Support Suite and use the new UFSx Support Suite. UFS_DCTxBB5 V 2.3.0.2 ---------------------- 1. BB5 RAPU Based Products USB Flashing / UI support added: RM-884 (302) 2. DCT4 INFINEON Based Products Flashing / UI support added: RM-908,RM-924,RM-925,RM-926,RM-928,RM-929,RM-961,RM-962 (105,210,.. 210,107,106) 3. Added HiBauds (up to 3Mbaud) on UFST Box, for Infineon XG101 and XG110 Platforms. 4. DCT4 MTK Based Products UI support added: RM-944,RM-945 (108) 5. Windows8 64bit support. UFS_ATRz v2.3.0.2 ------------------ 1. Increased Baud Rate for J220,J230 2. Windows8 64bit support. UFS_KZF v2.3.0.2 ----------------- 1. Added Windows8 64 bit Support. UFS_RTP v2.3.0.2 ---------------- 1. Added Windows8 64 bit Support. SeDBx v2.3.0.2 -------------- 1. Added Windows8 64 bit Support. LG v 2.3.0.2 ------------ 1. Common: Windows8 64bit support. SAMs V 2.3.0.2 -------------- SWIFT-AEROFONE E1260B,E1260L added (PUNL,PIM,FL) E1265,E2262 added (UNL,SECT,IM,FL) INFINEON C3322i,C3590,C3592 added (CUNL,PUNL,PIM,FL,UFL) Many thanks to all those who have supported us!!! Official SarasSoft Mirrors:- http://forum.gsmhosting.com/vbb/f311...tions-1216246/ Last edited by Odia The Ultimate; 10-28-2013 at 11:52. |
The Following 170 Users Say Thank You to GsmMunna For This Useful Post: |
![]() | #48 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,046 | UFSx+HWK Release 10/03/2014 Release 10//03/2014 WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. You need to uninstall (old HWK Setup Suite and HWK Support Suite) or existing (UFSx Support Suite) and use the new UFSx Support Suite. SAMs V 2.3.0.3 -------------- SWIFT-AEROFONE E1500 added (PUNL,PIM,FL) S3330,S5270Y added (UNL,SECT,IM,FL) COMMON Fixed bugs (Long time of DHLT & Keys Calc, USB HDD issue, ...) Customers who are experiencing the panel hanging on "check box" or "update box", should try to use the older driver and see if the problem is gone. How to install older driver. ------------------------------ 1. Make sure your UFSx device is connected to your PC. 2. Right click "My Computer" and "select Manage" 3. Click "Universal Serial Bus controllers" 4. Right click "UFSx Device, (c) SarasSoft" and select "Uninstall" 5. Right click your computer name at the top of the list and select "Scan for hardware changes" 6. When the Hardware Wizard opens, Select "No, not this time" and then Click "Next" 7. Select "Install from a list or specific location (Advanced)" and then Click "Next" 8. Make sure "Search for the driver in these locations" is selected, "Search removable media ..." is deselected and "Include this location in the search:" is selected 9. Click "Browse" and select either:- for x86 Windows - C:\Program Files\SarasSoft\UFS\UFS_USB_Driver\OLD for x64 Windows - C:\Program Files (x86)\SarasSoft\UFS\UFS_USB_Driver\OLD 10.Click "Next", click "Continue anyway" to any messages and then "Finish" You have now installed the old driver, when you run UFS_Panel, you should see these driver versions:- Versions: Ufs2xx.dll 3.1.19, Ufs2xx.sys 2.6.0 if you see Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 then you are still using the latest drivers and you should try the above process again. Many thanks to all those who have supported us!!! Official SarasSoft Mirrors:- http://forum.gsmhosting.com/vbb/f311...tions-1216246/ Last edited by Odia The Ultimate; 03-28-2014 at 14:11. |
The Following 5 Users Say Thank You to Odia The Ultimate For This Useful Post: |
![]() | #49 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,046 | UFSx+HWK Release 05/07/2014 Release 05//07/2014 WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. You need to uninstall (old HWK Setup Suite and HWK Support Suite) or existing (UFSx Support Suite) and use the new UFSx Support Suite. SAMs V 2.3.0.4 ----------------- INFINEON SM-B312E added (CUNL,PUNL,PIM,FL,UFL) ANDROID More Products and Features added. UFS Turbo & UFST only, see separate Document. COMMON Added File Archive Path Selection. Customers who are experiencing the panel hanging on "check box" or "update box", should try to use the older driver and see if the problem is gone. How to install older driver. ------------------------------ 1. Make sure your UFSx device is connected to your PC. 2. Right click "My Computer" and "select Manage" 3. Click "Universal Serial Bus controllers" 4. Right click "UFSx Device, (c) SarasSoft" and select "Uninstall" 5. Right click your computer name at the top of the list and select "Scan for hardware changes" 6. When the Hardware Wizard opens, Select "No, not this time" and then Click "Next" 7. Select "Install from a list or specific location (Advanced)" and then Click "Next" 8. Make sure "Search for the driver in these locations" is selected, "Search removable media ..." is deselected and "Include this location in the search:" is selected 9. Click "Browse" and select either:- for x86 Windows - C:\Program Files\SarasSoft\UFS\UFS_USB_Driver\OLD for x64 Windows - C:\Program Files (x86)\SarasSoft\UFS\UFS_USB_Driver\OLD 10.Click "Next", click "Continue anyway" to any messages and then "Finish" You have now installed the old driver, when you run UFS_Panel, you should see these driver versions:- Versions: Ufs2xx.dll 3.1.19, Ufs2xx.sys 2.6.0 if you see Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 then you are still using the latest drivers and you should try the above process again. Many thanks to all those who have supported us!!! Official SarasSoft Mirrors:- ★★ UFSx+HWK Install Files Mirrors & Install Instructions ★★ |
![]() | #50 (permalink) |
Member: 4042 Status: Offline Thanks Meter: 24,046 | UFSx+HWK Release 17/07/2014 Release 17/07/2014 WARNING !!! If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk. You need to uninstall (old HWK Setup Suite and HWK Support Suite) or existing (UFSx Support Suite) and use the new UFSx Support Suite. SAMs V 2.3.0.4 build32 -------------------------- ANDROID More Products and Features added. UFST only, see separate Document. LG_GSM V 2.3.0.4 build 32 ------------------------------ 1. Common: Added File Archive Path Selection. 2. Fixed some common bugs. Customers who are experiencing the panel hanging on "check box" or "update box", should try to use the older driver and see if the problem is gone. How to install older driver. ------------------------------ 1. Make sure your UFSx device is connected to your PC. 2. Right click "My Computer" and "select Manage" 3. Click "Universal Serial Bus controllers" 4. Right click "UFSx Device, (c) SarasSoft" and select "Uninstall" 5. Right click your computer name at the top of the list and select "Scan for hardware changes" 6. When the Hardware Wizard opens, Select "No, not this time" and then Click "Next" 7. Select "Install from a list or specific location (Advanced)" and then Click "Next" 8. Make sure "Search for the driver in these locations" is selected, "Search removable media ..." is deselected and "Include this location in the search:" is selected 9. Click "Browse" and select either:- for x86 Windows - C:\Program Files\SarasSoft\UFS\UFS_USB_Driver\OLD for x64 Windows - C:\Program Files (x86)\SarasSoft\UFS\UFS_USB_Driver\OLD 10.Click "Next", click "Continue anyway" to any messages and then "Finish" You have now installed the old driver, when you run UFS_Panel, you should see these driver versions:- Versions: Ufs2xx.dll 3.1.19, Ufs2xx.sys 2.6.0 if you see Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 then you are still using the latest drivers and you should try the above process again. Many thanks to all those who have supported us!!! Official SarasSoft Mirrors:- http://forum.gsmhosting.com/vbb/f311...tions-1216246/ |
The Following 4 Users Say Thank You to Odia The Ultimate For This Useful Post: |
