unable to flash c5212 i am unable to flash c5212 , the set is working without sim but with sim it hangs on samsung MCU File: C5212DDIK1_master.cla CRC32: 02E6CAB7 TFS File: C5212DDIK1_master.tfs CRC32: F5A21E72 CFG File: C5212DDIK1_master.cfg 143731 byte(s) MCU File: C5212DDIK1_slave.cla CRC32: 9220DDCC TFS File: C5212DDIK1_slave.tfs CRC32: 03812417 CFG File: C5212DDIK1_slave.cfg 1005 byte(s) MCU Id: 3B11, PNX6508/13/16/17 Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:11 File CRC: 0x02E6CAB7 MCU Write Done, 25923052 byte(s), Time: 06:49 File CRC: 0xF5A21E72 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 159 Max_Files : 1784 Files_Count: 1784/1784 TFS Unmounted TFS Write Done, 34970017 byte(s), Time: 13:14 Slave 1st Boot Failed: help me |
logs are showing flash done |
Slave 1st Boot Failed: master sim flashing done not slave |
i think it is the problem related to slave sim as the imei is also being shone of slave sim is not in numbers , its like abschh6877 etc .. |
both should be flashed separately |
Odia. |
same problem flashing with battery.without battery works perfect |
is it possible to flqsh ou unlock G FEN model-5212 on UFS hWK Thanks in advance |
