05-05-2008, 10:39 | #1 (permalink) |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | Can't unlock this phone sagem 220x from tmobile can you fix this ?? 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Can't continue #0! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Can't continue #0! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Can't continue #0! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! I unlock on the sam cable 5 pcs and this is log from few 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Can't continue #0! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Can't continue #0! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Can't continue #0! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! Direct unlock succeeded. IMEI: 35572801607077-0 1. Remove the battery and then insert it again! 2. Press Power ON shortly! Direct unlock succeeded. IMEI: 35572801349107-8 1. Remove the battery and then insert it again! 2. Press Power ON shortly! Then on my side all is ok only last pcs sagem 220x got problem I waiting for info why if you need I can send you flash.bin from this phone becosue flash was readed without problems. I waiting for info. bye |
05-05-2008, 10:49 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | did phone imei good? i have that problem some days ago but i don't reminber how i solve the problem. anyway it was not problem in sagdd soft! just check around you, connection, comport,Imei etc.... |
05-05-2008, 11:59 | #3 (permalink) |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | @wgmmmx PROBLEM: Can't continue #0! - means incorrect/destroyed data in security area. Check IMEI ! Sent flash.bin to [email protected], don't forget to attach box S/N and simple problem explanation note. br |
05-05-2008, 16:28 | #4 (permalink) | |
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | Quote:
05-05-2008, 16:45 | #5 (permalink) | |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @wgmmmx I see you has unlocked successfully 2 phones Quote:
So, SagemEG can unlock my220X and all other E-GOLDlite phones. I not know what hapened with last one. Probably you tried to unlock phone with empty battery. If you want to get solution, send flash.bin and backup to [email protected] | |
05-05-2008, 19:24 | #6 (permalink) | |
1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! I got this when try unlock but read flash files work. bye | |
05-05-2008, 19:41 | #7 (permalink) |
Member: 9544 Status: Offline Thanks Meter: 5,533 | @wgmmmx "Bootloader failed" means that you can`t read flash.bin too. But you has read it. Loaders for flash read and for unlock are same. So, you has got cable problem or phone battery was empty. 100%! |
1650 ascii 11 can't work with UB with other box ok can you fix this ?? | wgmmmx | Universalbox | 4 | 10-22-2008 16:00 |
Z400 can't unlock with 3.08 can you fix this ? | wgmmmx | Ultimate-Sam | 1 | 07-18-2008 18:03 |
Can't unlock this sagem 220x can you fix this ? | wgmmmx | FuriousGold | 1 | 05-05-2008 23:04 |
G800L can't unlock Can you fix this ?? | wgmmmx | Easy-Unlocker | 4 | 03-11-2008 15:42 |
can't unlock 2630 v4.90 can you fix this ???? | wgmmmx | MT-BOX | 16 | 01-25-2008 09:57 |
