emporia v29 emporia talk premium v29 tmobile hr 07/27/11 07:32:59] 2. Press Power ON shortly! [07/27/11 07:32:59] 1. Remove the battery and then insert it again! [07/27/11 07:32:59] [07/27/11 07:33:05] Factory settings restored. [07/27/11 07:33:05] Required Time: 00:00:01 [07/27/11 07:33:05] Elapsed Time: 00:00:07 [07/27/11 07:33:30] [07/27/11 07:33:30] Firmware: 04.20.00:18.26.19:08.10.00:ULC2GL [07/27/11 07:33:30] IMEI: 356669025978802 [07/27/11 07:33:30] [07/27/11 07:33:30] 2. Press Power ON shortly! [07/27/11 07:33:30] 1. Remove the battery and then insert it again! [07/27/11 07:33:30] [07/27/11 07:33:35] PROBLEM: Direct unlock failed! [07/27/11 07:33:35] Elapsed Time: 00:00:05 i have buy code but dont see any way to enter code via keypad on board is printed emporia et_v20x_B_v1.0 2008-10-08 |
There are different V29/V29i Firmwares available and not all supported with SagemEG |
also i gett one v29 emporia talkpremium Firmware: 04.17.00:18.26.16:08.07.00:ULC2GL unlock is succesfull but phone still locked 00:03:40] Firmware: 04.17.00:18.26.16:08.07.00:ULC2GL [08/02/11 00:03:40] IMEI: 356669025547318 [08/02/11 00:03:40] [08/02/11 00:03:44] 2. Press Power ON shortly! [08/02/11 00:03:44] 1. Remove the battery and then insert it again! [08/02/11 00:03:44] [08/02/11 00:03:56] IMEI: 35666902554731-8 [08/02/11 00:03:56] Direct unlock succeeded. when i putt other simcard mesagge is sim karte einlegen t mobile readout from phone is 2shared - download Flash_35666902554731-8.rar |
Thank you for report we will check it. Quote:
@Fill This phone can be unlocked via build in SagemEG Emporia NCK Calculator Press ZTE S302/Emporia life+/TELME C121 ... button, put phone IMEI and network operator code select type - Emporia Life+ and press Get unlock code button start phone w/o SIM card in, enter code from server and press Green button looks like ... Network Operator : 23203 NCK : ###3854#997X577X# post report Quote:
i will trz now and report thanx oxo |
[09/11/14 20:19:53] Firmware: 04.17.00:18.26.16:08.07.00:ULC2GL [09/11/14 20:19:53] IMEI: 356669025745102 [09/11/14 20:19:53] [09/11/14 20:19:57] 2. Press Power ON shortly! [09/11/14 20:19:57] 1. Remove the battery and then insert it again! [09/11/14 20:19:58] [09/11/14 20:20:08] IMEI: 35666902574510-2 [09/11/14 20:20:08] Direct unlock succeeded. [09/11/14 20:20:08] Required Time: 00:00:12 [09/11/14 20:20:08] Elapsed Time: 00:00:15 same like @fill , did you suceed? after code calculation... |
