02-28-2008, 10:25 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Problem My411v Hardware Failure i've recieved one Sagem my411v , my worker didn't check it properly and just unlock it using SAGDD and it calculated the code successfully but when i check it it was saying hardware failure, so when i try to repair i check the box hardware failure Code timer reset and clicking on repair i click again on do job so it again say direct unlock succeeded and deducted 1 more log so i lost 2 logs and fone is still on Hardware Failure and then i connect again and this time i usre Repair button and it give me error that it can't be reapaired, here is the log. [02/28/08 12:15:42] 2. Press Power ON shortly! [02/28/08 12:15:42] 1. Remove the battery and then insert it again! [02/28/08 12:15:42] [02/28/08 12:16:27] PROBLEM: Repair not possible! [02/28/08 12:08:40] Server:\> 12 paid credits left. [02/28/08 12:09:48] Server:\> 35515001120827-3; Code: 04481245-72; Phone Code: 0000 [02/28/08 12:11:38] Server:\> 35515001120827-3; Code: 04481245-72; Phone Code: 0000 [02/28/08 12:13:11] Server:\> 10 paid credits left. any help will be appriciated Take Care ENJOY |
02-28-2008, 10:40 | #2 (permalink) |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | 1.Use SagDD V7.3 and fully charged phone battery. 2.Connect to server and plug cable in phone (phone must be off); 3.Check 'Hardware failure' option ONLY, and press |Repair|! 4.Press shortly phone power on btn. 5. etc... That is correct away! br Last edited by Oxo_Boxo; 02-28-2008 at 11:52. |
02-28-2008, 11:00 | #3 (permalink) |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | i'm using v7.3 and if u see my first log and read my post i did the same thing but it says PROBLEM: Repair Not Possible. Thank u for ur Reply Take Care ENJOY |
02-28-2008, 11:49 | #4 (permalink) |
Member: 12837 Status: Offline Thanks Meter: 2,740 | I think you can see the difference now... btw. As we advice in first post - you must read flash.bin and sent to [email protected] or [email protected] in similar cases. br |
my411v hardware failure | zullu2004 | Sagem Hardware Repair Area | 1 | 01-26-2008 10:58 |
mw3026 hardware failure problem helppppp | kenwood | Infineon C16X M51 & ARM7 M52 BASED | 1 | 12-02-2003 00:00 |
"Sagem MC939" Hardware failure repair with power-sound | Sedy | ARM9 BASED M62 / M62+ | 2 | 07-05-2000 08:53 |
Hardware Failure with Sagem MC930 | FireWolf | ARM9 BASED M62 / M62+ | 10 | 06-30-2000 23:37 |
MC939 Hardware failure | saulius_znatavicius | ARM9 BASED M62 / M62+ | 0 | 05-22-2000 09:59 |
