my400v Hardware failure i use sagem doctor but cant read, also i use sagem furios calc but same problem i show only "no rate found i use this: A- Cable Sagem MYC-2 B- SoftWare Sagem furious Calculator - Cracked- 1- Start Sagem furious Calculator. 2- Go to Setting shoose your Com Port ** COM1 or.......** and Thread Priority ** Normal **. 3- Go to Bootsrap and communication. 4- Let Answer Mode ** HEX ** 5- Power ON the phone and connect it 6- Press **Connect** Answer Ok 7- Fill in box **Field number** 268 and Press **Read** answer OK Field 268 (2 bytes): XXXX 8- show **Field data** XXXX 9- Change this value To 0000 10- Press **Write** Answer Ok 11- Power OF the phone 12- Hop its all Ok |
repair two minut my400v Hardware failure today repair two minut my400v Hardware failure solucion; 1 start sagem tools selektion baudrate 19200 2 start sagem dr14c 3 com1 4 selektion 5 edit eprom field 5 Field 268 (2 bytes): 0c00 6 repair field 268 ---- 0000 7 successfully 8 sagdd unlock procedura its ok thanks skenda from prishtina email [email protected] |
