Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SAGEM JTAG UNLOCKER
Old 04-10-2006, 20:12   #1 (permalink)
Member: 110986
Thanks Meter: 12
Myc-4 problem with testpoint
I have a Myc-4 for unlock,but from the 4 points of the testpoint, 2 are exfoliated.(the second and the third,from the bottom to the top).
Is there any other solution to put the 2 wires(yellow and white) of the testpoint somewhere else?
thanks a lot!
Old 04-10-2006, 20:21   #2 (permalink)
Member: 9544
Thanks Meter: 5,533
Read this thread:
http:///vbb/showthread.php?t=245236
I recommend solution with soft pencil and TP adapter!
Old 04-10-2006, 20:46   #3 (permalink)
Member: 110986
Thanks Meter: 12
thanks,but I tried all solutions,but didn't worked.
I thought that maybe I could wire somewhere else.(is it possible?)
Old 04-10-2006, 21:26   #4 (permalink)
Member: 9544
Thanks Meter: 5,533
@neluturap
What pencil you used?
Must be >4B !
Old 04-11-2006, 12:47   #5 (permalink)
Member: 81703
Thanks Meter: 1,332
So maybe...I had a problem with a myv55 TP, one of needles flight because I pressed too much. Could I use the pencil solution here?just repacing the needle by the pen?
Thanks in advance
Problems with testpoint on A1000 James_S Smart-Clip 9 05-05-2008 08:45
problem with testpoint cable V-spec Matrix rev J.A.F. V-SPEC 2 03-28-2008 14:48
MTBox PRO problem with Testpoint DonaldDuck69 MT-BOX 6 08-21-2007 08:00
Problems with testpoint! phone_abuser Sony Ericsson 0 08-31-2004 00:24
T180 - dead - problem with testpoint tozitom Motorola Old Legacy (EMMI) 0 04-08-2004 19:49
Page generated in 0.14764 seconds with 10 queries
