GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   SAGEM JTAG UNLOCKER (https://forum.gsmhosting.com/vbb/f312/)
-   -   /Sagem DD dont work/ I can`t work with SagDD. ? (https://forum.gsmhosting.com/vbb/f312/sagem-dd-dont-work-i-can-t-work-sagdd-579970/)
surfer2go 08-14-2008 15:51
hi
I have bought sagem DD box a few weeks ago becouse I had a few vodafone 226 fones with theese phones it worked but it doesnt work with any other fone
I have tried : My x1trio, my201x, z55, my 210x, my100x
and it does not work with all I have testpoint adapters but it doesnīt work
The strange thing is that unlocking only works with Sagem EG 8.1(vodafone 226) Sagem DD 8.3 doesnt work at all for me and Sagem DD 7.5 also doesnt work
the soft recognize my Box with serial etc server connection is also established but allway faild to set phone speed or faild to read imei
what can be wrong is my sagem DD damaged ?
latigido 08-14-2008 16:03
@surfer2go
You must rename your post to
I can`t work with SagDD!!!:mad:
Read all in first Post here:
http:///vbb/...d.php?t=526394
Especially read attached pdf documents!
mrfixit 08-14-2008 23:50
usually cable problem, my scdr2 cables look the same but dont work with my sagdd, hope this hint helps, good luck. (maybe ur supplier mixed up sagdd with scdr2 cables)
Tetouan Gsm 08-15-2008 02:24
i agree with surfer2go i have some problem ..all is correct and i read manual i try a tp but already same error message :failed to set phone speed or failed to read imei and other mesage error in 6% and 10%
latigido 08-15-2008 05:41
@Tetouan Gsm
I not agree with you!
How many cables you has got with SagDD box?
Read again pdf documents in Sagem Jtag Unlocker thread here.
Also loks previous post.
http:///vbb/...37&postcount=3
CONCORDIA GSM 08-15-2008 05:50
Originally Posted by tetouan Gsm (Post 3568526)
i Agree With Surfer2go I Have Some Problem ..all Is Correct And I Read Manual I Try A Tp But Already Same Error Message :failed To Set Phone Speed Or Failed To Read Imei And Other Mesage Error In 6% And 10%
I Dont Think So
I Always Gett Success With Great Sagdd And Never Failed Because I
Always Read Manuals Carefully Before I Done Any Work Related By. ;)
Brod Aries 08-15-2008 07:48
i have also encountered those problems before, but after i shortened my tp cables i see results...try it. ;)
br
*phone-company* 08-15-2008 17:42
hm i had a few problems with sagDD but after short break and checkup...i know was little problem wit my brain ;) just simple solution is read manuals..try to use search function before make new posts here... very easy
sagDD ist best solution for sagem phones
Tetouan Gsm 08-16-2008 02:07
The problem that i read manual is very easy to read ..ther's one manual: with tp and without tp means usb and rj45..i understand manual and picture is very clair but when i try to unlock somthing already failed imei but o i will try and try sure i get it if ihave problem o post screen ..thank you freinds
.::Skylinks::. 08-19-2008 09:39
Solution is Clear
For M62,M62+,M63,M64 etc : Sagem DD 8.3
For Egold phones: Sagem EG 8.1
There is no Cable problem if you,ll unlock Egold phones with Sagem DD then sure you,ll get error...
surfer2go 08-20-2008 11:19
i read all carefully again and again and I also know the difference between Sagem DD and EG but it doesnīt work so what should i Tell you Iīm not a programmer or something like that so I donīt realy know why it does not work but it does not
Oxo_Boxo 08-20-2008 11:47
Just try to explain yours activity step by step ...
What phone type you try to unlock, which software and cables are you use...
how connect phone to pc/box...etc...
orbita 08-20-2008 17:22
sagDD is one of better box from market.
don't have bugs,easy to use,price/performance is very good.
only 2 "problem" have this box.
old lpt port and missing flashing support.
unlocked many sagem,and mostly problem was from my side.
bad TP conection,problem with internet,phone problem e.t.c.
@surfer2go
try read manuals,use good PC with good lpt port and will be OK;)
Page generated in 0.18217 seconds with 6 queries
