Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SAGEM JTAG UNLOCKER
Old 08-14-2008, 15:51   #1 (permalink)
Member: 4615
/Sagem DD dont work/ I can`t work with SagDD. ?
hi
I have bought sagem DD box a few weeks ago becouse I had a few vodafone 226 fones with theese phones it worked but it doesnt work with any other fone
I have tried : My x1trio, my201x, z55, my 210x, my100x
and it does not work with all I have testpoint adapters but it doesnīt work
The strange thing is that unlocking only works with Sagem EG 8.1(vodafone 226) Sagem DD 8.3 doesnt work at all for me and Sagem DD 7.5 also doesnt work
the soft recognize my Box with serial etc server connection is also established but allway faild to set phone speed or faild to read imei
what can be wrong is my sagem DD damaged ?
Old 08-14-2008, 16:03   #2 (permalink)
Member: 9544
Thanks Meter: 5,533
@surfer2go
You must rename your post to
I can`t work with SagDD!!!
Read all in first Post here:
http:///vbb/...d.php?t=526394
Especially read attached pdf documents!
Old 08-14-2008, 23:50   #3 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 788
usually cable problem, my scdr2 cables look the same but dont work with my sagdd, hope this hint helps, good luck. (maybe ur supplier mixed up sagdd with scdr2 cables)
Old 08-15-2008, 02:24   #4 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thanks Meter: 188
i agree with surfer2go i have some problem ..all is correct and i read manual i try a tp but already same error message :failed to set phone speed or failed to read imei and other mesage error in 6% and 10%
Old 08-15-2008, 05:41   #5 (permalink)
Member: 9544
Thanks Meter: 5,533
@Tetouan Gsm
I not agree with you!
How many cables you has got with SagDD box?
Read again pdf documents in Sagem Jtag Unlocker thread here.
Also loks previous post.
http:///vbb/...37&postcount=3
Old 08-15-2008, 05:50   #6 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
Originally Posted by tetouan Gsm View Post
i Agree With Surfer2go I Have Some Problem ..all Is Correct And I Read Manual I Try A Tp But Already Same Error Message :failed To Set Phone Speed Or Failed To Read Imei And Other Mesage Error In 6% And 10%
I Dont Think So
I Always Gett Success With Great Sagdd And Never Failed Because I
Always Read Manuals Carefully Before I Done Any Work Related By.
Old 08-15-2008, 07:48   #7 (permalink)
Member: 257511
Thanks Meter: 69
i have also encountered those problems before, but after i shortened my tp cables i see results...try it.
br
Old 08-15-2008, 17:42   #8 (permalink)
*phone-company*'s Avatar
Member: 60001
Sonork: 100.106474
Thanks Meter: 151
hm i had a few problems with sagDD but after short break and checkup...i know was little problem wit my brain just simple solution is read manuals..try to use search function before make new posts here... very easy
sagDD ist best solution for sagem phones
Old 08-16-2008, 02:07   #9 (permalink)
Member: 190492
Thanks Meter: 188
The problem that i read manual is very easy to read ..ther's one manual: with tp and without tp means usb and rj45..i understand manual and picture is very clair but when i try to unlock somthing already failed imei but o i will try and try sure i get it if ihave problem o post screen ..thank you freinds
Old 08-19-2008, 09:39   #10 (permalink)
.::Skylinks::.'s Avatar
Member: 300354
Sonork: 100.1577485
Thanks Meter: 760
Solution is Clear
For M62,M62+,M63,M64 etc : Sagem DD 8.3
For Egold phones: Sagem EG 8.1
There is no Cable problem if you,ll unlock Egold phones with Sagem DD then sure you,ll get error...
Old 08-20-2008, 11:19   #11 (permalink)
Member: 4615
i read all carefully again and again and I also know the difference between Sagem DD and EG but it doesnīt work so what should i Tell you Iīm not a programmer or something like that so I donīt realy know why it does not work but it does not
Old 08-20-2008, 11:47   #12 (permalink)
Member: 12837
Thanks Meter: 2,740
Just try to explain yours activity step by step ...
What phone type you try to unlock, which software and cables are you use...
how connect phone to pc/box...etc...
Old 08-20-2008, 17:22   #13 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,908
sagDD is one of better box from market.
don't have bugs,easy to use,price/performance is very good.
only 2 "problem" have this box.
old lpt port and missing flashing support.
unlocked many sagem,and mostly problem was from my side.
bad TP conection,problem with internet,phone problem e.t.c.
@surfer2go
try read manuals,use good PC with good lpt port and will be OK
Can I unlock sagem My600 with sagDD? gsmfriend SAGEM JTAG UNLOCKER 5 04-14-2009 09:56
succsesfully unlock sagem my300c with sagem dd Harkishan singh SAGEM JTAG UNLOCKER 0 02-02-2009 07:31
succsessfully unlock sagem myx-2 with sagem dd Harkishan singh SAGEM JTAG UNLOCKER 3 12-14-2008 20:20
Parallel PCI cards working with Sagem DD?! pacesetter SAGEM JTAG UNLOCKER 6 12-03-2008 01:57
can i unlock sagem my401c in sagem dd? zonetrichur SAGEM JTAG UNLOCKER 4 06-23-2007 21:21
Page generated in 0.17860 seconds with 9 queries
