sagem my101l how I can unlock the sagem my101l. . I have my cable box + Sagem JTAG. [IMG]http://www.************/forum/uploads/monthly_04_2009/post-3085-1240976310.jpg[/IMG] |
There is two type of My10x phones : - half of part are unlockabe via TP, and rest of them can be done via data cable only. All depends of MCU type. How to check it - search in section , we explain details several times. |
PROBLEM: Failed to read IMEI! PROBLEM: Failed to read IMEI! PROBLEM: Choose COM Port! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! Phone not started or wrong speed chosen! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Failed to read IMEI! PROBLEM: Setting phone speed failed! PROBLEM: Setting phone speed failed! PROBLEM: Setting phone speed failed! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! |
