Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SAGEM JTAG UNLOCKER
Old 03-18-2010, 09:16   #1 (permalink)
obama2's Avatar
Member: 952862
Thanks Meter: 48
can u fix this zte unlocked but still locked how to write eeprom
Direct unlock succeeded.
IMEI: 35949702019355-8
1. Remove the battery and then insert it again!
2. Press Power ON shortly!
IMEI: 004999010640000
Firmware: EF-UG-ORANGE-P108E1(S)V1.0.0B01
PROBLEM: Bootloader failed! (00)
PROBLEM: Phone not started!
The Following User Says Thank You to obama2 For This Useful Post:
Old 03-18-2010, 09:49   #2 (permalink)
Member: 12837
Thanks Meter: 2,740
@obama2
Did you try REPAIR function ?
The Following User Says Thank You to Oxo_Boxo For This Useful Post:
Old 03-18-2010, 09:52   #3 (permalink)
Member: 9544
Thanks Meter: 5,533
@obama2
Move Backup_004999010640000.bin in another folder.
Restore default lock!
Unlock phone again!
That is all!
BTW, use prolific cable if you want to reduce comunication problems with ZTE phones.
Just for info, eeprom ( static and dynamic) not have relation to your problem!
The Following User Says Thank You to latigido For This Useful Post:
Zte a306 shows unlocked but still locked kfkevin SAGEM JTAG UNLOCKER 7 03-24-2010 15:41
to elco how can i enter simlock code softbank 707sc2. unlock but still lock usim. dragories NSPRO 1 04-11-2009 16:33
zte 125 unlocked but still locked gsmservices Infinity-Box 9 06-21-2008 10:15
How to write eeprom to T100? zDEnaL VLSI, Conexant, Skyworks and Old Models 8 09-05-2002 23:14
how to write eeprom to aria? aklishin Mitsubishi 0 05-10-2001 11:08
Page generated in 0.15718 seconds with 9 queries
