Astro-Clip versus P207 and X480 How do I unlock these phones using Astro-Clip? Could not find them at Guide but at website the seem to be supported... Regards, Sergio |
I think that X480 is a white phone the same as P207, check that the phones yellow, red or green are just special phones. Maybe x480 can be a green one but I doubt it: 1. Connect 9V battery to the clip. 2. Power OFF your phone. 3. Connect Phone to the clip via right cable. 4. Press shortly unlock button in the clip. 5. If led goes Red press power ON in your phone and hold it until led goes Green - If led goes Green just wait. 6. Wait until led will blinks a few times. BR and post here if it worked well |
X480 is the same as T100 cable. Tried and phone turned on just after conecting cable. Unlocked using another method (software) and selecting C200 as model. Not sure what cable to use with P207. |
Maybe V200??I'm not sure about this...because in Teleway website they claim that p207 it's a cable completly different... BR |
x480 agere model same v200 cable |
still waiting for P207 info. My customer is getting angry... :( :( :( |
No news about P207 cable... Is it really supported? |
P207 cable is Usb and you must buy it or home made. You can also use original Usb cable for D500.Then follow this procedure gived by AstroTeam: Unlock solution for P207 Phone: 1. Install Samsung USB Driver 2. Run Update Software For Clip 3. Connect Clip to PC Via Update Cable. 4. Press unlock button in the clip (Untill led will go from Red to Green) 5. Click (Direct Unlocker) 6. Connect Phone to PC Via P207 Usb Cable. 7. Check In system , What is your Virtual Comport for your Samsung phone. 8. Choose this Comport Number in your Virtual Comport. 9. Click (Unlock P207) Button Check that was not announced E760 it's now supported!!! BR Luskao[AstroTeam BetaTester] |
Ok, just saw... but things are not so clear to me... D500 must be original or any USB-D500 cable will do? My clip is updated (at least to the last file on support - just noticed siemens c62 installer are not there anymore). I must connect clip using USB, Ok. And phone connected to USB to my PC too, correct? So... what software should I use? Thanks for helping |
D500 must be original, no china cables. If you want pinout for usb p207 I will find you. You must download new updater with support for unlocking from PC. BR |
@sdantas: Pinout for Samsung P207 original OEM cable can be found here http://pinouts.ru/data/samsung_p207_pinout.shtml |
Update was not avaiable when I posted ;) Thanks. |
@sdantas: Sorry, feel free to be corrected but Samsung P207 via original OEM cable was supported since we released an update for it (1st October). But simply, we just forgot to add it's unlock procedure to the sticky guide. |
Hummm, where can I find/download this new updater with support for unlocking from PC. BR, |
