Box not going to test-mode anymore Hi, Just got a SE K600 to upgrade. Changed button to BOX, connected USB cable and holded Unlock button pressed. But green light doesn't light on :( Seems like unlock button is not working anymore... just tried to unlock a E635 and nothing... :( Any idea? BR, |
Do you use USB Hub or standart computer USB port? |
standard computer USB port NEVER connected USB and power at the same time |
No suggestion? Should I return to my reseller? :( |
Try to update clip again. BR Luskao |
How can I update if box only connect to pc when i test mode? :( :( :( :( :( :( :( :( :( |
You can select manually where is connected. select that comport and update it.Will work. BR Luskao |
just tried. Clip not found. :( I sleected COM manually. Didn't helped :( |
maybe clip is damaged? |
Maybe... but HOW it happened? I don't leave it connected all the time. always connected it using USB, expcept for two or three times I used a 9v battery... strange... |
@UnlockBR: Strange problem, I will forward this message to our technical guy as i stated on Sonork yesterday and keep you notified in this week. |
Ok, I will be really greatful. Don't wanna see my clip dead... |
@AstroTeam, Any news from your technical guy? Regards, Sergio |
@UnlockBR: Exchange your clip at your reseller, an critical hardware failure has occured in your case. |
Ok. I will check with my reseller. If they refund me, may I join your beta test group? sonork, msn or MP if u prefer ;) Regards, |
