Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Astro Clip
Old 12-20-2005, 13:49   #1 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
Red face Box not going to test-mode anymore
Hi,
Just got a SE K600 to upgrade. Changed button to BOX, connected USB cable and holded Unlock button pressed. But green light doesn't light on
Seems like unlock button is not working anymore... just tried to unlock a E635 and nothing...
Any idea?
BR,
Old 12-20-2005, 13:56   #2 (permalink)
AstroTeam's Avatar
Member: 167856
Thanks Meter: 4
Do you use USB Hub or standart computer USB port?
Old 12-20-2005, 15:00   #3 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
standard computer USB port
NEVER connected USB and power at the same time
Old 12-21-2005, 12:25   #4 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
No suggestion? Should I return to my reseller?
Old 12-21-2005, 14:54   #5 (permalink)
Member: 81703
Thanks Meter: 1,332
Try to update clip again.
Luskao
Old 12-21-2005, 14:57   #6 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
Luskao
How can I update if box only connect to pc when i test mode?
Old 12-21-2005, 16:08   #7 (permalink)
Member: 81703
Thanks Meter: 1,332
You can select manually where is connected. select that comport and update it.Will work.
Luskao
Old 12-21-2005, 18:58   #8 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
just tried.
Clip not found.
I sleected COM manually. Didn't helped
Old 12-21-2005, 19:19   #9 (permalink)
EndlessConnections's Avatar
Member: 21371
Thanks Meter: 24
maybe clip is damaged?
Old 12-21-2005, 22:52   #10 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
Maybe... but HOW it happened? I don't leave it connected all the time. always connected it using USB, expcept for two or three times I used a 9v battery...
strange...
Old 12-22-2005, 02:06   #11 (permalink)
AstroTeam's Avatar
Member: 167856
Thanks Meter: 4
@UnlockBR:
Strange problem, I will forward this message to our technical guy as i stated on Sonork yesterday and keep you notified in this week.
Old 12-22-2005, 12:47   #12 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
Ok, I will be really greatful.
Don't wanna see my clip dead...
Old 12-27-2005, 02:01   #13 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
@AstroTeam,
Any news from your technical guy?
Regards,
Sergio
Old 12-27-2005, 03:16   #14 (permalink)
AstroTeam's Avatar
Member: 167856
Thanks Meter: 4
@UnlockBR:
Exchange your clip at your reseller, an critical hardware failure has occured in your case.
Old 12-27-2005, 05:01   #15 (permalink)
UnlockBR's Avatar
Member: 26751
Thanks Meter: 2
Ok. I will check with my reseller. If they refund me, may I join your beta test group?
sonork, msn or MP if u prefer
Regards,
N93 will not go into test mode Mobile2001 Federal One 1 10-17-2006 11:25
After upgrading 6280 from 3.70 to 5.92 phone won`t go to test mode any more! robbie HWK 8 10-17-2006 10:34
gx15 not going in test mode mdshad1 Sharp 8 07-26-2005 04:37
X70 not going into test mode tical Griffin 1 10-21-2004 21:01
Page generated in 0.22919 seconds with 10 queries
