Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Astro Clip
Old 10-14-2005, 20:38   #1 (permalink)
Member: 106232
Thanks Meter: 2
Pls help astroclipteam
hi ,
i buy 5 pcs astro clip but my problem is same error "clip not found "
step
astro updater install
usb connection
clip mode
after press unlock button
5sec i wait
after press read clip info
same problem clip not found
b.r
Old 10-14-2005, 21:28   #2 (permalink)
Member: 81703
Thanks Meter: 1,332
BOX MODE!!You have to put it in box mode...It's normal, you want to use it as box or as clip??
Old 10-14-2005, 21:29   #3 (permalink)
AstroTeam's Avatar
Member: 167856
Thanks Meter: 4
Run software and press ''Read Info'' button, and press unlock button in clip and make sure that clip is in Box mode.
Your clip will be detected and information will be readed, if this will not apply then you will have to uninstall it in device manager and reinstall drivers from scratch.
Make sure that checkbox ''Auto find my clip'' is selected.
Old 10-14-2005, 22:10   #4 (permalink)
Member: 106232
Thanks Meter: 2
I think driver bad ?
Old 10-14-2005, 22:37   #5 (permalink)
Member: 106232
Thanks Meter: 2
with 9v battery or only usb cable connection need for update?
Old 10-14-2005, 23:18   #6 (permalink)
AstroTeam's Avatar
Member: 167856
Thanks Meter: 4
@besthacker:
With USB-cable of course, we do recommend you to not use usb hub.
Old 10-14-2005, 23:34   #7 (permalink)
Member: 106232
Thanks Meter: 2
I not have usb hub direckt pc to box communucation but same problem tomarrow i chck other pc after i write here thx for help !!
Old 10-16-2005, 00:36   #8 (permalink)
Member: 106232
Thanks Meter: 2
hi,
i make 3 pcs update but other 2 pcs pc reset after clip dead u have repair soulution for this ?
Old 10-16-2005, 09:40   #9 (permalink)
Member: 81703
Thanks Meter: 1,332
Check what ia the port where you have the box and select comport manually. Update clip again and try it. Under Win98 it's extremly easy to update besides winxp sometimes something wrong happened. But just select comport manually
Old 10-16-2005, 18:46   #10 (permalink)
Member: 106232
Thanks Meter: 2
thx u info all ok %100
b,r
Old 10-17-2005, 19:49   #11 (permalink)
Member: 106232
Thanks Meter: 2
chck pls mail for activasyon file
Old 10-17-2005, 19:51   #12 (permalink)
Member: 81703
Thanks Meter: 1,332
I think they are on vacation...Be patient
Old 10-18-2005, 10:22   #13 (permalink)
Member: 58345
I'm still waiting the activation file for more than 4 days!!!!!!!
If I have bought the astro clip is because I need it and not to have it in the package
Old 10-18-2005, 14:38   #14 (permalink)
Member: 81703
Thanks Meter: 1,332
Jcosta, READ, they are on vacation, can them had a break or must work 365 days and 24 hours for you??
Be patient
Old 10-18-2005, 18:36   #15 (permalink)
Member: 58345
I cannot be pacient when I have bought one think that it is useless to me and when I'm loosing money.
I don´t wan´t them to work to me 365 days, but I have spent $250 in a box that is not working ( because is not activated).
It was the first time and the last one that I have bought anythink from Astro team.
infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? vintel Infinity-Box 4 03-07-2010 11:29
pls prob intalation driver of lg KS20 pls pls help GSM PAVIA FuriousGold 10 05-20-2008 22:58
pls pls pls help me for e65 sidah-gsm BB5BOX 4 01-28-2008 10:16
Pls Pls Pls Help Me ctg60000 WD2 & APE (Symbian Phones) 3 10-31-2006 12:50
PLS PLs PLS help me u8120 v102 hi red box help help sunnyc LG 1 11-17-2004 18:34
Page generated in 0.30780 seconds with 10 queries
