Pls help astroclipteam hi , i buy 5 pcs astro clip but my problem is same error "clip not found " step astro updater install usb connection clip mode after press unlock button 5sec i wait after press read clip info same problem clip not found b.r |
BOX MODE!!You have to put it in box mode...It's normal, you want to use it as box or as clip?? BR |
Run software and press ''Read Info'' button, and press unlock button in clip and make sure that clip is in Box mode. Your clip will be detected and information will be readed, if this will not apply then you will have to uninstall it in device manager and reinstall drivers from scratch. Make sure that checkbox ''Auto find my clip'' is selected. |
I think driver bad ? |
with 9v battery or only usb cable connection need for update? |
@besthacker: With USB-cable of course, we do recommend you to not use usb hub. |
I not have usb hub direckt pc to box communucation but same problem tomarrow i chck other pc after i write here thx for help !! |
hi, i make 3 pcs update but other 2 pcs pc reset after clip dead u have repair soulution for this ? |
Check what ia the port where you have the box and select comport manually. Update clip again and try it. Under Win98 it's extremly easy to update besides winxp sometimes something wrong happened. But just select comport manually BR |
thx u info all ok %100 b,r |
chck pls mail for activasyon file |
I think they are on vacation...Be patient :) |
I'm still waiting the activation file for more than 4 days!!!!!!! If I have bought the astro clip is because I need it and not to have it in the package |
Jcosta, READ, they are on vacation, can them had a break or must work 365 days and 24 hours for you?? Be patient BR |
I cannot be pacient when I have bought one think that it is useless to me and when I'm loosing money. I don´t wan´t them to work to me 365 days, but I have spent $250 in a box that is not working ( because is not activated). It was the first time and the last one that I have bought anythink from Astro team. |
