BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here. |
04-05-2002, 06:28 | #1 (permalink) |
Junior Member Join Date: Apr 2002 Location: Europe
Member: 10702 Status: Offline Thanks Meter: 0 | Alcatel BF cable schematic here !! Code: Alcatel BF-3, BF4 interface schematic 20 (4) |\ | _____ | /| DTR o------| >|-----|_____|-----+----------+----|< |-----+ |/ | 100 ohm + | | \ \| | ----- | | ----- 2.2uF | DZ 2V7 | | | ----- ----- | (GND) (GND) | | +------------+ | ____| 1 16 |-----+ + | | | | 2.2uF ----- | | ----- ----- | | ----- 2.2uF |____| 3 2 |_____| + | | | | + -----| 4 6 |--------| |---+ + | | | 2.2uF | | | ----- | MAX3232 | ----- ----- | | (GND) 2.2uF |_____| 5 | 3 (2) | | 4 RX o--------------------| 7 10 |----------------------o TA_MS (TX) 2 (3) | | 5 TX o--------------------| 8 9 |----------------------o AT_MS (RX) 6 (6) | | 2 DSR o--------------------| 14 11 |----------------------o AT_RCK | | 1N4148 4 (7) | | ____ |\ | 3 RTS o--------------------| 13 12 |-+-[____]--+-| >|-----o TA_ARQ | | | 5k6 | |/ | | | | | |____________| | |<-+ E | | B || | +-----||--+ C 7 (5) | BC252 | 1 GND o--------------------------+------------------+----------o GND | RS 232 | ALCATEL BF3, BF4 25 (9) pin FEMALE ----- phone connector (GND) ================================== Alcatel BF-3, BF4 Pinout description | | | | | BATTERY | | | | | |_______________________________________| | | | |_____________|_________________________| | _______________ | | | O O O O O | | --------------------------------------- 1 2 3 4 5 1 - GND 2 - AT_RCK 3 - TA_ARQ 4 - TA_MS (Tx) 5 - AT_MS (Rx) WARNING !! All pins voltage levels are 1.8v !! Must use MAX 3232 !! ================================== |
03-08-2004, 02:42 | #2 (permalink) |
Junior Member Join Date: Mar 2004
Member: 57206 Status: Offline Thanks Meter: 0 | I think you may have pins 4&5 on the phone around the wrong way. Also, a MAX232 does work (I used it on a BF3) but the MAX3232 is probably more reliable running from the lower voltage. |
I search for alcatel BF cable | vampire | Main Sales Section | 0 | 09-25-2002 21:40 |
Soft T39 and T68. Alcatel BF cable | elsamu | Wanted Products | 5 | 07-09-2002 01:49 |
Alcatel BF series Schematic box | Jackmaxo | BF, BG, TH, BHx Series | 0 | 06-16-2002 03:58 |
Alcatel BF cable schematics | Spalato | BF, BG, TH, BHx Series | 28 | 06-16-2002 03:43 |
