Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Hardware Repair
Alcatel TCL Hardware Repair here you can get all the Hardware Repair information for all Alcatel and Alcatel TCL Phones.
Old 02-20-2002, 21:45   #1 (permalink)
Member: 6689
Post alcatel db dead
i have a few alcatel db that are dead i reflowed the entire board but no joy any ideas will be appreciated
Old 02-21-2002, 09:46   #2 (permalink)
Member: 461
Thanks Meter: 2
Post
Try check all resistors in power area.<br />If you have software problem, use SW Alcatel repairer.<br />You can't read phones with any sw ??<br />
Old 02-22-2002, 05:30   #3 (permalink)
Member: 8898
Please replace Power IC, sure ok one...
Old 02-23-2002, 18:15   #4 (permalink)
Member: 7176
hai friend <br />follow these steps<br />1 first find whether its a hardware or software problem....if the resistance between the positive and negative terminals is less than 1000ohms its hardware complaint...you have to replace power ic....if you dont have power ic with you, you can try shorting pin number 2 and 3 of power ic...the phone will be ok....<br />2 if its a software problem use be1srv12.3to cure your phone...90%phone will be cured.. <br />3 if not cured the best software is andromeda5.9..try the user default option in it..if not cured you have to flash the phone using andromeda with correct version...<br />best of luck and please inform me about the result..<br />thanking all zfrank friends <br />sidhartha harish<br /> [email protected] <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> <img src="wink.gif" border="0">
Old 02-23-2002, 19:13   #5 (permalink)
Member: 6462
Post
i have four alcatel be4 dead
idon't know what's the pb
i selled with this pb
Old 03-01-2002, 03:53   #6 (permalink)
MobileSoft's Avatar
Member: 3355
Dead Alcatels
All dead alcatel wit hardware problem, usually PTW IC (Powerchip).
First try and short pin 2 and 3 if this not work - replace - Works most of the time!
To the South African dude who posted this msg - If u still need help or need any other help - Call me - 0827687778
Old 06-16-2002, 03:58   #7 (permalink)
Member: 8537
Thanks Meter: 7
where i find powerchip in pcb ??
alcatel db
Old 06-16-2002, 05:09   #8 (permalink)
ARS
Member: 2721
Thanks Meter: 23
Is it a big IC near SIM connector
PTWL2207
Old 06-16-2002, 06:16   #9 (permalink)
Member: 8537
Thanks Meter: 7
thanks ARS !!!
Old 10-13-2002, 06:50   #10 (permalink)
iqballk's Avatar
Member: 13932
Sonork: 100.1609876
Thanks Meter: 404
short 1+2+3 pins in ptw..
Alcatel DB- dead bbbbbb Alcatel TCL Hardware Repair 9 06-08-2004 23:06
alcatel db dead GSM RAJ Alcatel TCL Hardware Repair 0 09-29-2001 03:55
ALCATEL DB DEAD AFTER WRONG UNLOCK I PAY FOR GOOD SOLUTION xavien Alcatel & TCL Old Models 4 04-16-2001 12:36
i need help with dead alcatel db 16b 2 Mg Bolo Alcatel & TCL Old Models 0 04-22-2000 19:45
Alcatel DB Easy - dead, after flashing... Liquid Alcatel & TCL Old Models 0 03-17-2000 01:49
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.22605 seconds with 8 queries
