Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
09-01-2022, 19:15 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Does the device have regular imei and stuff ? network works, etc. ? b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
09-22-2022, 19:26 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
network works, etc ? have you tried to use mobile updater to restore it ? write all details here plz. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
09-26-2022, 19:50 | #6 (permalink) | |
post results b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
09-29-2022, 11:34 | #7 (permalink) | |
Crazy Poster Join Date: Apr 2018 Location: United Kingdom
Member: 2827375 Status: Offline Thanks Meter: 5 | Quote: Br, | |
09-29-2022, 22:29 | #8 (permalink) | |
so MobileUpgrade won't update/reflash it, so few ideas : 1 - read and check traceability partition, to see which is the current PID in device 1a - changing PID to retail one, then again use MobileUpgrade 2 - read firmware from working device (make all security backups first from your demo phone), then write to demo device 3 - (if phone allows) bootloader unlock, magisk, root, Titanium backup or similar - to remove demo*.apk there are more ideas, but these are first to do. p.s. You can try checking the PID with some of these codes : Code: Enter MMI test Input *#2886# in the dial pad (GL version) Input *#*#2886#*#* in the dial pad (AUCHAN version) To check the software version Input *#3228# in the dial pad (GL version) Input *#*#3228#*#* in the dial pad (AUCHAN version) b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 10-03-2022 at 19:00. Reason: add/remove info | |
09-30-2022, 09:36 | #9 (permalink) |
Member: 2827375 Status: Offline Thanks Meter: 5 | Thanks for the response the code for my device is 5039D-2*ALGBK which i know is kiosk mode and need to change it to ALGB1. What box would you recommend to read the data out of the device? As when I've tried boxes before i have no luck because it doesn't have the security to be able to unlock the device and extract the information out of it. Br, Last edited by Brka; 09-30-2022 at 20:23. Reason: removed quoting |
09-30-2022, 20:24 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | You can try with loader, any box that supports qualcomm devices (and custom loaders) p.s. if you manage to read traceability, use some hex editor to change pid inside it, write back and try updater. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 10-03-2022 at 18:58. Reason: add/remove some details |
10-03-2022, 19:00 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | And... we have found the solution. It has to be non-demo software (PID). b.r. Alex
10-03-2022, 19:03 | #13 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | And... we have found the solution. It has to be non-demo software (PID). Quote:
b.r. Alex
10-06-2022, 21:39 | #14 (permalink) |
No Life Poster Join Date: Sep 2012 Location: UK
Member: 1816005 Status: Offline Thanks Meter: 299 | Succesfully edited pid with nck dongle Code: Exe Version: NckDongle Qualcomm Module 0.13.2 Operation: Write Provider ID IMEI: 353317100123456 Model: 5039D-2BALGBK Secro: X2D0C201CX00 Writing: 5039D-ALGB1 and took effect when i check in traceability with *#2886# code ************************************* Code: There is no greater software version available to upgrade your device, actual version of your device is the latest Last edited by gsmro2012; 10-06-2022 at 21:49. |
10-07-2022, 00:50 | #15 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Either same or higher version already inside ... 2 ways to solve: - try with other same model device to put retail pid and update (after flash read that updated device and write to other) - service flasher must be used, it has refurbish options, so can reflash same version btw. is that the pid that you wrote ? - 5039D-ALGB1 ? because its not correct, must be 5039D-2BALGB1 make "traceability" partition read and upload somewhere, maybe i can fake sw version ... lets try b.r. Alex
