Alcatel 5038D Flash file plz someone share alcatel pop d5 flash file |
I Tried With This Firmware But Cellphone Still Hang At "Pop D5" Logo. My Cellphone Is Idea Alcatel 5038D Version : 2CIJIN3 Is There Any Version Available For My Cellphone Please ?. |
1 Attachment(s) Quote:
Maybe you did not flashed all files ? custpack.img and system.img files are mandatory to be flashed, together, and usually custpack missing, or corrupted in phone makes phone hang on logo. re-check all again (check attached picture), and re-flash. after flashing, enter recovery and do factory reset. if that don't work, try to install second attached rom file, from custom recovery. b.r. Alex |
after i flash this file the phone dead |
What Was The Problem Before Flash ?. |
2 Attachment(s) Quote:
Second, you didn't post any details of phone condition before flash. Anyway, there is always some procedure to follow, which I wrote many times here on forum : - Check if battery is charged enough (3.8+ volt) - Download attached scatter file, put it in unpacked ROM folder - Open SPFT and load scatter from ROM folder (MT6582_Android_scatter_emmc_5038D.txt) - Do phone flashing, see if it becomes alive. - If not, make full format from SPFT and retry flashing operation. - After finished, enter recovery and make Wipe Data / Cache, reboot phone - First boot takes some lonfer time If you followed those steps, you should have working phone. If you have IMEI problem (no imei/missing), use another scatter file, and flash NVRAM partition. b.r. Alex |
need ot 5038d firmware and tool alkatel ot 5038d stuk on logo need ot 5038d firmware and tool |
follows the intraction thanks bro. |
after flash this file phone dead sir , phone is rooted after flash this both "MT6582_Android_scatter_emmc_5038D" and "MT6582_Android_scatter" set is dead. any solution for this problem. |
b.r. ALex |
sir my 5038D, when power on or connect chager it showes pop d5 logo and goes to recovery mode, volume keys are ok , i flashed phone with this Full Russian ROM for unbrick (for SPFT) but same condition, what should i do now? |
just to be 100% sure it's not software problem. b.r. Alex |
