Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
02-04-2015, 06:15 | #1 (permalink) |
Registered User Join Date: Aug 2000 Location: Hungary
Member: 1815 Status: Offline Thanks Meter: 3 | I need help with alcatel idol I got phone with not power on state. I disassembled and the sticker contain only this info: C4JE56 ALDLWHLH5 I think this phone is one touch idol 6030x (one sim version) Someone totally erased phone now spiflashtool can't flash anything, i need proper pro info file and boot files. Maybe someone have backup from working phone? thanks in advance Tom |
02-05-2015, 01:14 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,786 | Quote:
0. Install OTU first, it will install drivers - get it HERE 1. Download SPFlashTools - HERE 2. Download "REVIVER" pack - HERE 3. Complete backup of phone prepared for SPFT - HERE 4. Attached modified Scatter file, to allow flashing of hidden regions, put it in folder where you unpacked full rom backup file. (not reviver pack). Tutorial / How-To : - Unpack all archives - Open SPFlashTools, Scatter-loading button, go to folder of reviver pack - Open Scatter, and select manually mobile_info file, press DOWNLOAD - Hold vol_up + power on button on phone, insert usb cable, wait for flashing done - After done, you should have phone starting, and entering stock recovery, but phone is still "stay on boot logo" condition. Power it off, charge battery if needed. - Now, in SPFT open previously copied Scatter file from FULL rom folder(Optimus_San_Remo_130322.....) - called MT6577_Android_scatter_emmc_FULL-FLASH.txt - Manually select next files : NVRAM, pro_info, Custpack, and Flash the phone - After done ... go to recovery and do format/wipe data / cache - Reboot the phone, see if it fully power on, - Check imei, check if it accept sim cards, unlock if needed. If all fine ... you can try editing pro_info file, and use online updater, to get desired PID onto it. (If it doesn't fully start - you can do the same, OTU updater will fix all). or You can also flash TWRP recovery, and restore rom backed up with it, which you will place on SDCard. Get TWRP recovery image (flashable with SPFT) - HERE TWRP Rom Backup : HERE Now, with all this ... you have material for job. Do it, and post results, we hope in success. b.r. Alex | |
The Following User Says Thank You to Brka For This Useful Post: |
