Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 03-23-2018, 00:52   #46 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
On working 4034X rom, install twrp recovery, and install custom (post #5) or stock backup rom.
As previously stated, all needed can be found on these 3 pages. (or post #5.)
or if you are too lazy - HERE
*** edit:
Found some more ROMs :
- Russian v01004 Stock backup 4034D , flash via "firmware upgrade" option in SPFT
- Stock rom backup via box LINK1 or LINK2 - Use scatter attached to this post if you get error loading, replace original
Try them, if you get brick after flash - try flash only preloader from 4034x rom, or preloader from some other rom.
You can "mix" files from different roms (like system.img, custpack.img) and use scatter files from other roms.
p.s. If it still breaks down after few weeks, it's definatly not software problem...
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 03-01-2019, 20:19   #47 (permalink)
Member: 1837743
i need rom alcatel 4034D
i need rom firmware for alcatel 4034D
4034D-2AVNRS1 vipmobile serbia
Old 03-01-2019, 22:55   #48 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Download : 4034D-2BVNRS1_3D3SEJS0_Original_Stock_ROM_by_bRkA
If your phone power on, UNTICK preloader when flashing.
test and post results.
b.r.
Alex
__________________
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 03-06-2019, 09:27   #49 (permalink)
Member: 2615661
Thanks Meter: 24
i need polish rom for Orange Rise 31 / Alcatel 4034X-2BRGMC3
Old 03-06-2019, 21:03   #50 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Please read this thread : Alcatal PIXI4 (4) 4034x Firmware Needed - GSM-Forum
and on last page, my last post.
Hopefully, that rom should have Poland lang, but no guarantee.
However, if you have bricked phone - that's how to unbrick it.
b.r.
Alex
__________________
Old 03-08-2019, 10:38   #51 (permalink)
Member: 2615661
Thanks Meter: 24
firmware working, but no poland language :/ u have other firmware?
Old 03-08-2019, 16:20   #52 (permalink)
b2k
Member: 59737
Sonork: 100.1603188
Thanks Meter: 18
As mentioned, write firmware (it's the only firmware which worked on my piece), edit proinfo (PL T-Mobile PID - you need to check) use mobile s upgrade gotu or however it is called and you are done.
If needed please let me know, will give you proinfo file from PL T-Mobile
Old 04-12-2019, 22:48   #53 (permalink)
Member: 2729693
Hello, I need firmware for 4034d - 2ARGRO1, can you help me?
Old 07-24-2019, 21:00   #54 (permalink)
Member: 2508042
Thanks Meter: 3
@Brka I have Alcatel 4034D 2AALE31, killed with xxxx box trying to reset frp...BROM error all i got...
I have tried with couple fw's i found but always same error. Even with xxxx or xxxxx ...do you have exactly fw which i need or suitable DA?
Old 08-08-2019, 19:58   #55 (permalink)
Member: 2085676
Thanks Meter: 299
alcatel 4034d flash file
flash file portugesse
4034d help
The Following User Says Thank You to samicool88 For This Useful Post:
Old 10-23-2019, 16:38   #56 (permalink)
bherkund's Avatar
Member: 1119917
Sonork: nedi
Thanks Meter: 190
Red face also i have this problem
Originally Posted by Brka View Post
Solution would be to fix preloader on some of commercial boxes,
then reflash correct firmware, without preloader.
b.r.
Alex
please tell me solution
Old 10-24-2019, 22:56   #57 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Post original PID of the phone.
4034d help
Don't have it. Use PID change method + official updater.
Read sticky threads please :
http://forum.gsmhosting.com/vbb/f317...first-1893215/
http://forum.gsmhosting.com/vbb/f317...phone-1896218/
Exactly as written on previous answer.
b.r.
Alex
__________________
Old 10-25-2019, 14:42   #58 (permalink)
bherkund's Avatar
Member: 1119917
Sonork: nedi
Thanks Meter: 190
Red face 4034d-2GALWE1 solution needed............
dear brka bro my set was ok just pattern and after format with xxxxxx box
now set is only logo on and i tried many files but same
set 4034d-2GALWE1 and please give me solution to revive
this set
Old 10-26-2019, 23:10   #59 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
this set
Retail phone, it should be easily updateable with official update tool.
Check here (post #2) :
b.r.
Alex
__________________
Old 12-15-2019, 14:28   #60 (permalink)
bazde21's Avatar
Member: 222092
Sonork: 1605557
Thanks Meter: 44
hi..
need help with Orange Rise31 4034x-2ARGMC3 stuck in logo
i flashed many firmware but same result
Page generated in 0.23449 seconds with 9 queries
