how to enter unlock code alcatel 5020t sir cant option to enter unlock code, any solution?? best regards |
i have code but can't enter option thanks |
I have same issue with my Alcatel 7024w from T Mobile USA - bought unlock code,but have no option to put the code in :( |
because counter was blocked. u need to full wipe phone and than u will have posibiliuty to enter code. |
CLIFFORD25502 :but it does not help me-I did full wipe from recovery and from menu too so many times without any progress :( in engineer mode is simme lock option grayed ...Think need reflash it,but booloader is locked and there is no firmware/update/ to download too :( |
Where u read that u need do wipe from recovery? u need to wipe it via adb ( adb wipe all ), but seems needed root for it. |
Will try when I came back to home,thank You for reply. |
Movileuropa You think 7024w Fierce or 5020t?As I understand,we both have unlock codes already,but no option to it in...and we need only reset unlock counter /I hope so/ |
have one and need a code service to buy the code. thanx and best wishes |
Have problem to switch Fierce in fastboot mode...enabled developer mode,usb debugging selected,power+volume down start,but it doesnot stop on android(?!?)and adb commands dont see Fierce on cable... |
alcate onetouch evolve 5020T Here is what you need to do. You need a differnt sim that don't go to the phone put it in the phone after taking out the original one put 2 sim in and wait to a phone key pad shows in put 23385694 and it should unlock your phone |
U must format it in recovery mode(Voldown+PowerON, navigate with volume buttons to clear eMMC, and then press the middle key on the touch). It will ask for the nck after U did it. ;) B.r. Ceru |
1 - Switch ON your Alcatel with a NOT ACCEPTED SIM Card, 2 - When the message "Enter Network Key" appears, enter the Unlock Code. *NOT ACCEPTED : means, to use a sim card from a network other than the network your Alcatel is locked to. OR 1 - Switch ON your Alcatel WITHOUT SIM Card, 2 - Then compose : *#0000*CODE#, 3 - To finish compose : *#0001*CODE#. |
