Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
09-17-2021, 22:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Morocco
Member: 1712203 Status: Offline Thanks Meter: 354 | Idol 4S 6070k Bootlop tried factory tools, but stuck on downloading , after 100% its start from 0% again i wait more 3 hours (3 times download and start again) same problem with Mobile Upgrade Q 5.2.7 (download loop) tried to edit "traceability" and same problem with another PID also tried file from other box support but phone go dead (MSM8952_Vodafone_ANDR_v6.0.1_VFD_900_idol4s_vdf_S mart_platinum7) i manage to write backup for previous firmware and now phone stuck on reboot loop as first state he came PID: 6070K-2AALWE7 lastly i got firmware 'Alcatel_OneTouch_Idol_4S_6070K_2XALEU7_AAP_050520 16) but cant write it because it's MBN format Last edited by Brka; 09-18-2021 at 19:52. Reason: removed factory tools info |
09-18-2021, 20:01 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,787 | Most probably, hardware issue (malfunctioned eMMC/Flash memory, battery, power ic, etc.) Factory updater must make it alive, if hardware is ok. And logically, hardware issues cant be fixed by software. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
09-18-2021, 22:38 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,787 | Quote:
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
09-18-2021, 23:01 | #5 (permalink) |
Member: 1712203 Status: Offline Thanks Meter: 354 | i see it , but this phone never got flashed how to conclude that its hardware problem what i got is file from box support but for VF900 as descriped should work but phone got in dead state and another firmware that had MBN format that can't be written can you offer to me anyfile to test |
09-18-2021, 23:23 | #6 (permalink) | |||
and this is enough old device to have it failed. not just flash ic ... it may be RAM ... who knows Quote:
I dont have any 6070k firmwares in my archive. now ... 1. disassemble phone 2. check for moisture/water damage, clean/gently reflow the board 3. recharge battery manually (should have at least 3.75V) 4. check/resolder/replace usb port on phone 5. re-assemble the phone 6. retry the process 7. if you are still getting the same errors, then read here why all of this ? on MTK alcatels, some older models dont want to flash when battery is drained ... so thats why you need to disassemble phone first and do one by one what i wrote on that checklist. again - no neet to download ANY firmware, factory "sweet" tool knows which one is right, and will download exact and correct latest firmware for device. If it cant boot the device - thats something else, but has nothing to do with software. booting issues can come up from windows, drivers, bad cable/usb port ... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 09-18-2021 at 23:33. Reason: added more info | |||
09-18-2021, 23:51 | #7 (permalink) | |
Member: 1712203 Status: Offline Thanks Meter: 354 | Quote:
not working the updater detect the phone and begin to download the firmware but when i got 100% it's start from the begning 0% again and again Last edited by Brka; 09-19-2021 at 21:13. Reason: removed factory tools logs/data | |
09-22-2021, 10:59 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,787 | As i wrote in previous posts... Cheap manufacturers, Use cheap/low-grade eMMC flash which tends to die very fast. However, it mostly dont die fully, Just get bad sectors in most used read/write areas which are userdata and cache. Some of them get into read-only state, etc etc This is just example... I've seen alcatels with corrupted otp area, dead boot area and many more. B.r Alex
The Following User Says Thank You to Brka For This Useful Post: |
