Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
09-28-2007, 07:50 | #1 (permalink) |
Junior Member Join Date: Jun 2005 Age: 45
Member: 152282 Status: Offline Thanks Meter: 42 | New ALCATEL_TCLdefault code HERE Full Factory Reset:? Phone Lock Code:? Default Security Code? Provider Pass Code:? and more..... THESE ARE SAMPLE ONLY,and some maybe not work...just test and post result...thANKS ###337*07#, ###847#. reset ###765*02# - Add ###765*05# - Lock ###765*07# - Delete ###765*08# - Unlock ###765*78# Master Codes - 25228352 - 25228353 - 83227423 (***/4,BH4,BF5,BG3,BF3/4..) ###337*07# - master reset (with SIM) ###847# - factory reset (with SIM) Alcatel 835 formating - **0102# alcatel vle5 phone kod; reset to factory seting no sim; ###847# for reset QUOTE "To reset phone code do next : BH4 - power phone ON without SIM - hold * and press 65512890 - wait for phone restarting Regards,Vygis" maybe will work (I didn't test on Cxxx ) c552 83227423 and then disable the user code manually in phone's menu, tested by me in 2 cells code : ###847# sur VLE5 Ok Alcatel HD1 , HE1 : 25228353 Alcatel BE1 , BE3 : 25228352 Alcatel BE4 : 83227423 Alcatel BE5 : 25228352 Alcatel BF3 , BF4 : 83227423 Alcatel BG3 : 83227423 VLE5 : ###847# chek this reset code ###337*07# 83227423 work on 557a, c552a for security code for me OT-C825 Reset Code: *#73738# Unlock the phone in case the lock function has been activated and the code lost(called Super code): 11223344 |
The Following 35 Users Say Thank You to eagle_b For This Useful Post: |
09-28-2007, 12:10 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | Thanks For This Codes ... Have To Try And Post The Result ..... |
The Following User Says Thank You to sharmin For This Useful Post: |
09-28-2007, 15:15 | #4 (permalink) |
Junior Member Join Date: Mar 2007
Member: 466603 Status: Offline Thanks Meter: 2 | Ot-c550x Tested with Alcatel OT-C550X, unlock didn't work. It ***** the locked list but does not provide any prompt to unlock without sim. |
The Following User Says Thank You to Antish For This Useful Post: |
10-18-2007, 17:52 | #13 (permalink) | |
Freak Poster Join Date: May 2004 Age: 50
Member: 65774 Status: Offline Thanks Meter: 4 | vle5 t&a Quote:
11-04-2007, 17:08 | #15 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 344467 Status: Offline Thanks Meter: 7 | -------------------------------------------------------------------------------- Please post here default code for New ALCATEL TCL default code here...needed,thanks... Full Factory Reset:? Phone Lock Code:? Default Security Code? Provider Pass Code:? and more..... THESE ARE SAMPLE ONLY,and some maybe not work...just test and post result...thANKS ###337*07#, ###847#. reset ###765*02# - Add ###765*05# - Lock ###765*07# - Delete ###765*08# - Unlock ###765*78# Master Codes - 25228352 - 25228353 - 83227423 (***/4,BH4,BF5,BG3,BF3/4..) ###337*07# - master reset (with SIM) ###847# - factory reset (with SIM) Alcatel 835 formating - **0102# alcatel vle5 phone kod; reset to factory seting no sim; ###847# for reset QUOTE "To reset phone code do next : BH4 - power phone ON without SIM - hold * and press 65512890 - wait for phone restarting Regards,Vygis" maybe will work (I didn't test on Cxxx ) c552 83227423 and then disable the user code manually in phone's menu, tested by me in 2 cells code : ###847# sur VLE5 Ok Alcatel HD1 , HE1 : 25228353 Alcatel BE1 , BE3 : 25228352 Alcatel BE4 : 83227423 Alcatel BE5 : 25228352 Alcatel BF3 , BF4 : 83227423 Alcatel BG3 : 83227423 VLE5 : ###847# chek this reset code ###337*07# 83227423 work on 557a, c552a for security code for me OT-C825 Reset Code: *#73738# Unlock the phone in case the lock function has been activated and the code lost(called Super code): 11223344 |
The Following 3 Users Say Thank You to master138 For This Useful Post: |
New ALCATEL_TCLdefault code HERE | MOBIL CLINIC | Alcatel TCL Phones and New Models | 1 | 12-04-2009 00:02 |
all trick end code for new gsm phone here | abc3b | Phone Unlocking Codes & Maps | 2 | 01-23-2006 23:18 |
!!! FREE all new Siemens Source codes here !!! | zulea | Siemens-Benq RingTones and WallPapers | 23 | 09-05-2003 18:30 |
Here is new source code | vz | GSM Programming & Reverse Engineering | 0 | 09-12-2002 06:53 |
