help me moto k1 no tunes working but speaker is working help me moto k1 no tunes working but speaker is working and i think that it softwar but i give it many version of softwar but tunes stell not working and i do prepair phone and no result |
Joining the question. Had more then 2,000 of them directly from the production line (new and original). At least 3 where with that problem. I suspect that MP3/MID encoder inside the processor is damaged or a cold soldering (after all they where all new). Never encountered similar problem in Motorola. Anyone have an idea or directions? |
this is a very common problem with motorola k1. but still now not received any solution from any of the member |
i think the problem is in the flexible board to display,i have that problem to yesterday....,then i replace the flexible with the new one and then the problem solved............. |
ok you can try that,but if that cant solve ur problem u can PM me because i work on motorola authorized service centre in indonesia........ |
I replaced the folder, it helped. thanx. It's also helped the problem "When you try to check the ring and you have white screen adter the ring and every tune is ringing in a single tune" (hard to explain this problem, but this solution also helped). |
and i want to now what is flexable ????? |
hmmm.... folder is the k1 without the main board. "Replaced the folder" meaning I took two k1's and replaced their caseing with each other. "Flexable" its a flexebale strip that connect the main board to the outer plastic. http://tanstartrade.com/images/b9de_1_b.jpg |
your problem is 100% software br... try full flash..... |
thanks for all :) Quote:
i have replaced with new flexable and it now working done and ihave doing that in two moto k1 with the same problem and solved by reblac flexabe thanks for all |
I know that this is long time ago post, but.... I had some weird buzzer problem... (phone was ringing normal on some sounds, but on some was only heavyly distorting) Flex/Flat change solved problem... (after buzzer speaker change & full flash serveral times) It looks that audio amp driver is on upper board of handset... http://i45.tinypic.com/zyet93.jpg BR Haltec |
