Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
06-03-2007, 04:42 | #6 (permalink) |
No Life Poster Join Date: Aug 2005 Location: SILIGURI Age: 46
Member: 170589 Status: Offline Thanks Meter: 1,848 | do the set respond on incoming or outgoing call if yes than check lcd and its connector... if not than full flash it |
The Following User Says Thank You to yashtel For This Useful Post: |
06-12-2007, 17:32 | #9 (permalink) | |
Junior Member Join Date: Feb 2007
Member: 445245 Status: Offline Thanks Meter: 2 | Quote:
Hi My unit responds to incoming and outgoing but the display is only white screen. I tried to remove LCD connector and put it back and the full display showed up but when I put the phone down its back to white screen. If I hold the upper portion of the phone where the LCD connector -the display will show up. What do you think will I do to keep the connector from loosing up. Thanks | |
06-13-2007, 21:08 | #11 (permalink) |
Freak Poster Join Date: Jun 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 52
Member: 70278 Status: Offline Thanks Meter: 19 | try this pic ,l hope will help u all ,this solution l try before ,but not 100% ,post reply |
The Following 3 Users Say Thank You to 5mobile For This Useful Post: |
11-05-2007, 12:23 | #14 (permalink) | |
Registered User Join Date: Apr 2006 Location: malaysia
Member: 255011 Status: Offline Thanks Meter: 56 | Quote:
01-21-2008, 20:01 | #15 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | if continuty of these points are ok than also make jumper or not? ..::HUM::.. |
The Following User Says Thank You to HUM For This Useful Post: |
C168 blue display | k_abhi | Motorola Hardware Repair | 7 | 12-29-2011 12:30 |
motorola c168 blue display solution pls.............................................. | manrew | Motorola Hardware Repair | 18 | 03-08-2010 07:52 |
2600 blanck display | mestine | Nokia Hardware & Hardware Repair | 1 | 06-15-2008 09:58 |
c168 only display lights is not working ??? | makkah mobile | Motorola Hardware Repair | 1 | 11-06-2007 04:25 |
X820 Blanck Display | neo_49 | UST Pro II | 0 | 07-23-2007 16:21 |
