GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Motorola Hardware Repair (https://forum.gsmhosting.com/vbb/f323/)
-   -   L6 no charge (https://forum.gsmhosting.com/vbb/f323/l6-no-charge-442216/)
A lay 09-12-2007 08:48
L6 no charge
hi all. i have L6 no charge, can help me any one,
meo786pk 09-12-2007 09:11
Dear brother,
L6 charge way, my fix
I don't guarantee that it will work for all charging problem but I fixed one that was not charging.
Symptom: No power up, power plugged in it says charging but finishes quickly, battery read only 1.6v. Universal charge detects no power.
Solution: Well I did not have a spare battery to swap with. Because the phone came alive charging when plugged in, suggests something to do with the battery. The phone was water damaged, I peeled off the battery plastic cover, the battery cell actually was fully charged after all the attempts and left overnight. The problem was caused by corrosion in the circuitry inside the battery. Clean it up, the voltage measured 4.06v, great! plug it in to phone and all is swell.
For people with invalid battery, try another battery 1st if it works then most likely your battery circuitry is shorting. A working battery measure 10kohms between -ve (pin4) and pin 3 (THERM) next to it; check that too.
Anyway check the circuit below, on L6 block diagram there is VR324 that goes to OWB (One Wire Bus), R910, R911 for current limiting look at the green charge color path. The battery is labeled 3.7v and charger is 5v; the zener is 6.93v just as an overvoltage protection.
Possible solution for other no charge & invalid battery, without the battery:
1) Check VR324 & VR325 not short by measuing Pin 4 to 1 & 2
2) Pin4 to Pin3 of battery = 10Kohms
3) Meassure at Pin 1 > +4v with USB charge & battery (need fly wire to battery) in if not check open R910 & R911, if they are OK
4) Check Q905 % Q906 FET at S & D if voltage is gating
Muhammad Afzal Meo
YOUSSEF1975 10-17-2007 14:01
L6 Problem Charge Solution
Finally i find, you must change the first fuse of the three little one at right who are parallel to the charge connector.
Begin with the number 2 on the picture.
Try and post your result !
http://forum.gsmhosting.com/vbb/C:\D...TIONS\MOTOROLA
YOUSSEF1975 10-17-2007 14:17
1 Attachment(s)
Here is the picture !
Try and post your result: Thanks
pablos1 10-27-2007 16:30
hi,i need muster resetcode for motorola l6 plz.anybody help.
pablos1 10-27-2007 16:39
motorola l6 earpiece not working,already i changed two earpiece but still same problem.plz help.
Djtybee 11-19-2007 12:20
Thank's meo786pk
It works for me!
Finally I changed Q903 Q905 Q906 and Q904 and now it's charge!
Br tybee
HUM 11-21-2007 01:26
any other circuit from which i take Q903 Q905 Q906 and Q904,bcoz i dont have other L6.
..::HUM::..
saqib_islam 01-26-2009 08:41
Your Problem Is 100% Solved here. Just Check this out.
Motorola L6 Not Charging Problem
Mobile Repairing Picture Help
Nokia Phones Repairing Section
Sonyericsson Phone Repairing Section
If you like the post please HIT THANKS BUTTON
sumun007 02-06-2009 16:40
I have motorola l6 but invalid battery and speaker problem.pls help me any body.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.10751 seconds with 6 queries
