Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
09-12-2007, 09:11 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | Dear brother, L6 charge way, my fix -------------------------------------------------------------------------------- I don't guarantee that it will work for all charging problem but I fixed one that was not charging. Symptom: No power up, power plugged in it says charging but finishes quickly, battery read only 1.6v. Universal charge detects no power. Solution: Well I did not have a spare battery to swap with. Because the phone came alive charging when plugged in, suggests something to do with the battery. The phone was water damaged, I peeled off the battery plastic cover, the battery cell actually was fully charged after all the attempts and left overnight. The problem was caused by corrosion in the circuitry inside the battery. Clean it up, the voltage measured 4.06v, great! plug it in to phone and all is swell. For people with invalid battery, try another battery 1st if it works then most likely your battery circuitry is shorting. A working battery measure 10kohms between -ve (pin4) and pin 3 (THERM) next to it; check that too. Anyway check the circuit below, on L6 block diagram there is VR324 that goes to OWB (One Wire Bus), R910, R911 for current limiting look at the green charge color path. The battery is labeled 3.7v and charger is 5v; the zener is 6.93v just as an overvoltage protection. Possible solution for other no charge & invalid battery, without the battery: 1) Check VR324 & VR325 not short by measuing Pin 4 to 1 & 2 2) Pin4 to Pin3 of battery = 10Kohms 3) Meassure at Pin 1 > +4v with USB charge & battery (need fly wire to battery) in if not check open R910 & R911, if they are OK 4) Check Q905 % Q906 FET at S & D if voltage is gating Muhammad Afzal Meo |
The Following User Says Thank You to meo786pk For This Useful Post: |
10-17-2007, 14:01 | #3 (permalink) |
Registered User Join Date: Oct 2006 Age: 48
Member: 362673 Status: Offline Thanks Meter: 37 | L6 Problem Charge Solution Finally i find, you must change the first fuse of the three little one at right who are parallel to the charge connector. Begin with the number 2 on the picture. Try and post your result ! |
10-17-2007, 14:01 | #4 (permalink) |
The Following User Says Thank You to YOUSSEF1975 For This Useful Post: |
01-26-2009, 08:41 | #10 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 446881 Status: Offline Thanks Meter: 707 | Your Problem Is 100% Solved here. Just Check this out. Motorola L6 Not Charging Problem Mobile Repairing Picture Help Nokia Phones Repairing Section Sonyericsson Phone Repairing Section If you like the post please HIT THANKS BUTTON |
The Following 7 Users Say Thank You to saqib_islam For This Useful Post: |
Motorola L6 not charging - shematic wanted | chip_2000 | Motorola Hardware Repair | 12 | 01-26-2009 08:45 |
L6 can"t charge!! | benson2727 | Motorola Hardware Repair | 10 | 04-30-2008 03:16 |
L6 don't charge | gogomit | Motorola Hardware Repair | 4 | 07-13-2007 00:20 |
l6 no display and no service | segun01 | Motorola Hardware Repair | 0 | 06-02-2007 21:01 |
L6 No Ring No Speacker Voice. | stanner_austin | Motorola Hardware Repair | 3 | 08-08-2006 19:39 |
