GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Motorola Hardware Repair (https://forum.gsmhosting.com/vbb/f323/)
-   -   Motorola L6 NETWORK PROBLEM. (https://forum.gsmhosting.com/vbb/f323/motorola-l6-network-problem-669822/)
odetundun 01-22-2009 02:44
Water damage motorola L6 fail to see network. please somebody show me with diagram how to solve this problem.
ner21 01-22-2009 03:07
hi
changes P.A ic
afif 02-05-2009 20:26
use tuning nvm or master reset
taieeb 02-05-2009 20:50
change the network cabel it works
Qiuene77 02-08-2009 10:24
charge cards
Can a debt consolidation loan eliminate your credit card debt? A consolidation loan might (or might not) be the key. There are several things you must consider when making the choice to consolidate debt using a debt consolidation loan.First, is a debt consolidation loan your best choice to eliminate or substantially reduce your debt? There are other options available to you, including credit counseling and bankruptcy. Obviously bankruptcy is a last resort. You must examine several factors when making your decision on which debt reduction / elimination strategy to use. You need to get information on debt consolidation to make the correct decision.?How much outstanding debt do you have??What is the interest rate of your current debt? Many credit cards have interest rates of 14% - 22%, depending upon your credit rating and payment history. Obviously, the higher your current average interest rate, the better off you will be if you consolidate your debt with a consolidation loan at a much lower rate.?How much of your outstanding debt is unsecured? Unsecured debt has no collateral against it. Credit cards, student loans, store charge cards and medical bills are examples of unsecured debt. If you have over $7,500 in unsecured debt there a multitude of lenders that you can look at. Student loans fall into a different classification from other types of unsecured debt. In the United States, most are backed by the federal government. Usually you will have to use a secured debt consolidation loan to pay off your unsecured loans. You may also be able to refinance your secured debts, but you usually cannot consolidate secured debts.?Do you own a home or other substantial assets to use as collateral for a debt consolidation loan? If you own a Home or other real estate, how much equity do you have in it??What type of interest rate is available to you for a consolidation loan? The interest rate you receive on your loan is affected by a multitude of factors including the prime rate. For student loans, maple story mesos the borrower interest rate on consolidation loans is currently calculated as the weighted average of the interest rates in effect on the loans being consolidated, rounded up to the nearest one-eighth of 1 percent. They are capped at 8.25 percent.?How is your credit rating? Someone with a very good credit score has options open to them that those with wow power leveling lesser credit ratings do not.Keep in mind that if you have more than 20% equity in your home, you are usually not required to carry private mortgage insurance (PMI). If you have reached the 20% equity stage through either paying down the principal, asset appreciation, or both, you can probably drop PMI and lower your payment. wow power leveling On the flip side, if you are not paying PMI and you take out a consolidation or other Home equity loan, you may put yourself back under the 20% equity threshold. This would require you to get a new PMI policy. Factor this in when making your cost / benefit analysis.If you are constantly slipping backward and your cash flow is poor, you can improve things with a debt consolidation loan. Be careful and weigh your options carefully. Take into account the tax benefits archlord gold you may receive by using a Home equity loan to consolidate your debt. This benefit will vary depending upon your tax rate. You can get many free quotes for debt consolidation loans. There are several places that have multiple lenders compete for your Business. Talk to several lenders to see which will give you the most favorable terms. You can substantially lower your monthly payment buy archlord gold and significantly improve your cash flow situation with a debt consolidation loan. Just make sure this is the right choice for your needs.
vaibhavkumbhani 02-10-2009 07:00
pls solution pls ...............bharat.....
choto 02-20-2009 05:49
generaly not solve , just little heat net section
.:JOAB:. 02-20-2009 06:22
Posible solution for you, tested many times.
Resold all the components in the impedance matching network after watch de board with water and detergent, tested and work in 80% of the cases.
Good Luck
edgar velasquez 02-24-2009 03:53
solution
http://www.4shared.com/file/89179497...ervicio_1.html
simplenkd 01-18-2010 10:40
thanks............................................ ....................
apurba maitra 10-31-2010 18:43
thanks for need full help
Page generated in 0.11657 seconds with 6 queries
