Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
03-24-2007, 12:57 | #724 (permalink) | |
Insane Poster Join Date: Nov 2005
Member: 196233 Status: Offline Thanks Meter: 53 | l6 display Quote:
Hi Andy4wisdom, Please check cable flex so If you want read it carefully, it is Moto bulletin, If you need more info contact to me.. Regards, Ozitech Problem Service is aware that some GSM L6 phones have been returned with complaints of no display. The failure analysis revealed that flex cable was damaged due to rework process at factory. During disassembly of display module, flex cable can be caught by the metal insert on the chassis (see figure 1). When removing display module, flex cable needs to be carefully handled through the slot on chassis metal insert. In some cases, operator might have pulled the flex without enough care, and flex cable was thorn. Figure 1: location of slot on chassis metal insert, and area where damage is caused on flex cable Solution This problem has been addressed by Work Instruction at factory, implemented by February 13th, 2006. When disassembling L6 display module, the following procedure is advised: The slot on the chassis metal insert can catch this area, during disassembly Damage on flex cable normally appears here Slot on chassis metal insert 1. First, remove the battery cover, battery, rear housing, and transceiver PC board as described in the Service Manual procedures. 2. Use the metal tweezers to release the display module assembly latches located at the side of the display module (see Figure 2). Figure 2: Releasing display module latch 3. Lift up the top edge of the display module (see figure 3) Figure 3: lifting up display module for removal 4. Carefully thread the display flex cable through the slot in the chassis assembly and lift the display module away from the chassis. 5. To replace, align the display module to the chassis assembly. 6. Hold the side of the display module near the flex cable away from the chassis assembly. 7. Carefully thread the display flex connector through the opening on the chassis assembly. 8. Lower the display module fully onto the chassis assembly and gently press it into place. 9. Reassemble the transceiver PC board, antenna, SIM, battery, and battery cover as described in the Service Manual procedures. Authorized Service Centers need to adhere to these disassembly instructions, which are already informed by GSM L6 Service Manual. Service Action Customer Returns: When servicing GSM L6 returns, with complaint of No Display, then: 1. If the customer complaint is confirmed, then: a) Swap display module with a new display module. Please follow assembly/disassembly instructions from Service Manual, so damage to flex cable can be avoided at Authorized Service Center. Instructions are included above in this FSB. b) Retest the unit to verify proper operation. | |
03-24-2007, 13:18 | #725 (permalink) | |
Member: 196233 Status: Offline Thanks Meter: 53 | Quote:
Hi Can u read circuit diagram Regards, Ozitech | |
The Following User Says Thank You to ozitech For This Useful Post: |
03-24-2007, 13:29 | #726 (permalink) | |
Hi , They have solution but nobody doesnt spend that time and PCAP IC money 1. have to check current ( battery ) 2. have to check drying current ( power amp side ) 3. check it circuit diagram measures if it doesnt similar measurement have to be replace PCAP and success probabilty % 25 Regards, Ozitech | |
03-24-2007, 13:46 | #730 (permalink) | |
Hi ARe you sure new mic is works fine. Just put new mic and if its still faulty , carefully relflow PCAP ic its behind battery connector, put more liquid flux and both side use heater. Regards, Ozitech | |
new motorola hardware repaire tools | Athie_dede | Motorola Hardware Repair | 1 | 03-08-2018 14:58 |
NEW IN STOCK: GENIE UNIVERSAL, NEW 2010 hardware version !!! | Gobi | Main Sales Section | 0 | 11-07-2009 11:56 |
new motorola Hardware Repair | rubel_chakaria | Motorola Hardware Repair | 1 | 07-27-2009 23:32 |
New nokia hardware collection in one pack+new flash files | aleenasager | GSM Mobile Links | 4 | 10-24-2008 16:45 |
Need Motorola Hardware! | drucrew | Main Sales Section | 0 | 02-16-2002 00:21 |
