Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
01-04-2010, 09:02 | #1 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1200015 Status: Offline Thanks Meter: 1 | How to make your own iPhone Ringtone with iPhone Ringtone maker(for Windows/Mac) Why always buy expensive music or ringtone online as your iPhone ringtone? Now with the released of ********* iPhone Ringtone Maker and ****** iPhone Ringtone Creator for Mac, no matter you are Windows or Mac user, you can make your own special ringtone at will! The following content includes two parts, which will show you the steps to maker iphone ringtone. Part 1: How to make iPhone Ringtone with ********* iPhone Ringtone Maker(for Windows) Part 2: How to make iPhone Ringtone with ****** iPhone Ringtone Creator for Mac(for Mac) Part 1: How to make iPhone Ringtone with ********* iPhone Ringtone Maker(for Windows) Make preparation: Download ********* iPhone Ringtone Maker, install and run it. Step 1: Click "Browse…" button on the right side of "Input File" to import the file(audio or video file) that you want to make ringtone from it. Step 2: Click "Play" button to listen the music to find the segment that you want to use it as ringtone. Then drag and click the start & end slider to set your wanted segment, or type the start & end time in the corresponding text box directly to get the exact segment. Click "Preplay" to pre-listen the converted audio before generate. Step 3: Click "Browse…" button on the right side of "Local Output Folder" to choose the output destination. Step 4: Check "Export to iPhone" option, the converted ringtone will be load to your iPhone directly. Click "Manage Ringtone" to edit the added iPhone ringtone by removing it or renaming it directly. Step 5: After all the settings are finished, click "Generate" button to begin making your own iPhone ringtone. Part 2: How to make iPhone Ringtone with ****** iPhone Ringtone Creator for Mac(for Mac) Make preparation: Download ****** iPhone Ringtone Creator for Mac Step 1: Click "Browse…" button on the right side of "Input File" to import the file(audio or video file) that you want to make ringtone from it. Step 2: Click "Play" button to listen the music to find the segment that you want to use it as ringtone. Then drag and click the start & end slider to set your wanted segment, or type the start & end time in the corresponding text box directly to get the exact segment. Click "Preplay" to pre-listen the converted audio before generate. Step 3: Click "Browse…" button on the right side of "Local Output Folder" to choose the output destination. Step 4: Check "Export to iPhone" option, the converted ringtone will be load to your iPhone directly. Click "Edit Ringtone" to edit the added iPhone ringtone by removing it or renaming it directly. Step 5: After all the settings are finished, click "Generate" button to begin making your own iPhone ringtone. So look, make your own iPhone Ringtone is so easy and fast, have a try now! |
The Following User Says Thank You to gossipgirl5237 For This Useful Post: |
How to make your own iPhone Ringtone with iPhone Ringtone maker(for Windows/Mac) | baisang521 | LG | 1 | 11-02-2009 12:25 |
