Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
11-15-2006, 10:23 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 48
Member: 65863 Status: Offline Thanks Meter: 15 | V3 V3I sound problem any solution please thx in adv |
11-16-2006, 02:49 | #5 (permalink) |
Junior Member Join Date: Nov 2006
Member: 383057 Status: Offline Thanks Meter: 0 | Is the buzz coming from the keypad when the keypad light is on? Try using the phone in a bright room or ******** in the sun so that the keypad light will not light up and then see if the buzz goes away. If that's what you're hearing then that's normal, it's caused by the electroluminescent panel. |
11-17-2006, 16:08 | #8 (permalink) |
Freak Poster Join Date: Sep 2005 Location: united kingdom Age: 49
Member: 182216 Status: Offline Thanks Meter: 24 | check that the main pcb is not liquid damaged,wash and clean with vineager {the best solution} or replace LCD or LCD ribbon with the side buttons attached to it,mite work... |
11-18-2006, 10:41 | #9 (permalink) |
Member: 65863 Status: Offline Thanks Meter: 15 | for the V3 i cleaned the pcb for water damage ,changed under keypad , changed ringer capacitore still the same when the ringer work with the voice i have a shee zee sound onley when the ringer work what about the V3i allways a continouse light zee from the speaker when allway the phone is working no matter the speaker works changed underkeypad washed the pcb changed the speaker still the same thx in adv |
03-22-2008, 18:14 | #13 (permalink) | |
Freak Poster Join Date: Jan 2005 Age: 54
Member: 109136 Status: Offline Thanks Meter: 17 | Quote:
YES MOTOCAT IS RIGHT | |
04-20-2008, 22:10 | #15 (permalink) |
Crazy Poster Join Date: Apr 2007
Member: 491426 Status: Offline Thanks Meter: 3 | actually i have same problem and there is no sound ic the links come from power ic (uem) and one (nlas44599) dpdt analoge switch but its for hand free .. so i cant under stand what the problem.. |
V3 and V3i earpiece problem | GSM_BLUE | Motorola Hardware Repair | 8 | 09-03-2007 14:48 |
Motorola V3/V3i keypad light problem | Rahat_Gilani | Hardware Repair by brands | 2 | 05-12-2007 09:26 |
V3 RAZR sound problem | regor | Motorola P2k | 1 | 04-21-2007 21:26 |
V3 interesting sound problem | spulber001 | Motorola Hardware Repair | 3 | 12-29-2006 20:27 |
Lang change on V3/v3i | fedjak | Smart-Clip | 0 | 01-04-2006 11:30 |
