V3 camera freezing phone Plz MY V3 camera freez fon when u go to camera section .I try to repair PDA and flash with file R374_G_0E.42.10R_A but still same problem. So kindly help me fellow mates :confused: |
bro, try to change flex.............. |
try change camera bro.. |
Open up the phones face plate and make sure the camera flex cable is has no slits, after make sure it is connected properly no dust etc. between connectors, power on the phone again and check if camera is working if not, if you have another razr lying around use this camera on there and see if it gives same problems if not then it must be something other then the camera, somewhere on the board, or the lcd, or the flex cable, you have to trouble shoot it out. |
change the screen or the camera if it freezing up whenever you use the camera |
happened to me once.. i change the flex and camera.. |
Found that the I change LCD flex cable and it worked... Strange |
Hi tyo all I have same pro with v3 phone freez when camera on so I try as some frends say to change camera but still the same also I remove camera from phone and its freez with or without camera At least problem was flex I chang flex phone work fine and tack photo |
