Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 11-15-2006, 10:23   #1 (permalink)
Member: 65863
Thanks Meter: 15
V3 V3I sound problem
i recived V3 with a buzzing (zeee) sound with the ringer when useing the ringer and a V3I with continuase buzzing (zeee) sound with the speaker even if it is not useing the speaker
any solution please
thx in adv
Old 11-15-2006, 14:41   #2 (permalink)
Member: 375706
u can try to change powerr i.c
Old 11-15-2006, 15:48   #3 (permalink)
Member: 65863
Thanks Meter: 15
which ic do u have picture
thx in adv
Old 11-16-2006, 01:52   #4 (permalink)
Member: 63431
I had this problem b4 with my V3, just simply change the buzzer and the capacitor will do..
Old 11-16-2006, 02:49   #5 (permalink)
Member: 383057
any solution please
thx in adv
Is the buzz coming from the keypad when the keypad light is on? Try using the phone in a bright room or ******** in the sun so that the keypad light will not light up and then see if the buzz goes away. If that's what you're hearing then that's normal, it's caused by the electroluminescent panel.
Old 11-16-2006, 08:13   #6 (permalink)
Member: 65863
Thanks Meter: 15
thnks all
for the( V3 )i changed the buzzer but still the same a shshshshsh zeeee sound when the buzzer workes
any one have a solution please
Old 11-17-2006, 08:06   #7 (permalink)
Member: 383057
What's a buzzer?
btw, ALL V3 phones produce a buzz when the keypad light is ON.
Old 11-17-2006, 16:08   #8 (permalink)
Dr cellular uk's Avatar
Member: 182216
Thanks Meter: 24
check that the main pcb is not liquid damaged,wash and clean with vineager {the best solution}
or replace LCD or LCD ribbon with the side buttons attached to it,mite work...
Old 11-18-2006, 10:41   #9 (permalink)
Member: 65863
Thanks Meter: 15
for the V3 i cleaned the pcb for water damage ,changed under keypad , changed ringer capacitore still the same when the ringer work with the voice i have a shee zee sound onley when the ringer work
what about the V3i allways a continouse light zee from the speaker when allway the phone is working no matter the speaker works changed underkeypad washed the pcb changed the speaker still the same
thx in adv
Old 11-21-2006, 08:03   #10 (permalink)
Member: 65863
Thanks Meter: 15
no one with a solution please
Old 07-09-2007, 10:28   #11 (permalink)
Member: 45716
Thanks Meter: 38
i have the same problem bro pls post if you find any solution thaks
Old 03-22-2008, 17:36   #12 (permalink)
Member: 442579
Thanks Meter: 9
it very hard i change uem but same proplem
Old 03-22-2008, 18:14   #13 (permalink)
hiteshsangadia's Avatar
Member: 109136
Thanks Meter: 17
YES MOTOCAT IS RIGHT
Old 03-26-2008, 19:54   #14 (permalink)
Teepat's Avatar
Member: 599669
Thanks Meter: 115
v3
sir, just open the panel for the sound ic and rehot.your problem will be 100% solved.post reply.
Old 04-20-2008, 22:10   #15 (permalink)
Crazy Poster
Member: 491426
Thanks Meter: 3
actually i have same problem and there is no sound ic the links come from power ic (uem) and one (nlas44599) dpdt analoge switch but its for hand free .. so i cant under stand what the problem..
V3 and V3i earpiece problem GSM_BLUE Motorola Hardware Repair 8 09-03-2007 14:48
Motorola V3/V3i keypad light problem Rahat_Gilani Hardware Repair by brands 2 05-12-2007 09:26
V3 RAZR sound problem regor Motorola P2k 1 04-21-2007 21:26
V3 interesting sound problem spulber001 Motorola Hardware Repair 3 12-29-2006 20:27
Lang change on V3/v3i fedjak Smart-Clip 0 01-04-2006 11:30
Page generated in 0.21319 seconds with 9 queries
