Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 12-15-2017, 21:27   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,234
xt1625 g4 plus charging problem
xt1625 g4 plus when insert charger it show charging and also increase percentage
but when remove charger .....charging indication remains
I replace usb connecter but same
any idea about location of charging ic ?
Old 12-16-2017, 22:37   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,234
any solution...........?
Old 12-16-2017, 22:45   #3 (permalink)
samusprime's Avatar
Member: 189984
Thanks Meter: 112
Check thermistor located near to the flashlight.
Old 12-17-2017, 00:02   #4 (permalink)
efrcom's Avatar
Member: 128481
Thanks Meter: 367
XT1625 charging IC = U2400
The Following User Says Thank You to efrcom For This Useful Post:
Old 12-17-2017, 00:50   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,234
where is location......?
kindly share schematics sir
Old 12-17-2017, 02:16   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,234
ok i got the location of u2400
i remove c5000 and c5017 from id line but same
when i insert charger it show charging but when remove charger the charging indication remians
but when charge with computer it charge and no charging indication after remove usb cable
any solution ?
is this u2400 bad or some other parts ?
Old 12-18-2017, 11:54   #7 (permalink)
efrcom's Avatar
Member: 128481
Thanks Meter: 367
change u2400=PMI8952 IC
Old 01-07-2018, 13:20   #8 (permalink)
Member: 2792392
Thanks Meter: 13
I am also suffer this problem many times I replase g4+ c/c but charging showing only percentage not increase please help me thanks
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12351 seconds with 7 queries
