02-24-2008, 00:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Nokia Tools v4.0I - full ASK/RPL cache, NPC/HWC/CCC/Variant CERT Extraction, etc Known issues: RPL Write may not work through FBUS interface (USB recommended). Will be fixed in official release, as this is public-test only. Changes: Backup files is now written when IMEI is damaged (includes ????) Added full support for ASK/RPL operations. Cert restore is done clicking just one button (Restore Certificates). To restore certificate you need activated account on our server with logs inside. Logs prices will be fixed upon official release. First time you need just click "Restore Certificates". Software will contact our server and download RPL file. Our software supports certificate request through few ways: - USB cable (CA-53, DKU-2) via FBUS interface (phone switched on/in local mode) - USB cable (CA-53, DKU-2) using flashmode BootROM (if phone can't switch on, or go to local mode - its dead) - UFSx FBUS - if phone working ok - UFSx FlashBUS - f phone can't switch on, or go to local mode - its dead Our software supports RPL caching - that means if you will use your account to generate RPL file, it will be stored on server permamently. If you will lose your RPL file, you can re-download it any time you need. Same situation if someone already generated RPL for this PublicID - software will download RPL from server without any fees! If no RPL file for given PublicID is avaiable on server, software will place ASK file for calculation in queue - all you need to do now is just trying to download RPL file clicking "Restore Certificates". If your RPL will be finally calculated, software will download it, decrypt and will try to write to phone. It can repair blocked keypad/fbus counter, damaged SP area (FFFF), SX4 authorization problems (superdongle key), repair DRM keys, repair CMLA keys, and recreate PM from scratch if phone will be damaged somehow. Don't forget to use SX4 authorization and write good PM to correct calibration problems. As long as we dont have built-in FlashBUS yet, its not possible to write NPC/HWC/CCC/VARIANT certificates. But we have solution. If our software during writing RPL file will found unsupported certificate - it will be extracted to binary format - so no more problems with repairing damaged IMEI for example (NPC cert) - in BIN format you can write it via HWK in example. If there is some problems with writing RPL using our software, you can download it and save to HD and write by any Nokia software, even original (we using original NMP format). Just tick "Save RPL to file". If you have already RPL file in NMP format, then tick "Restore using local RPL file" and point software to local RPL file - so you avoid server transaction. Please test and post results & feedback, note you need to unpack RAR to current Nokia Tool directory in order to work properly, download from: http://www.karwossuite.pl/ks40i_test...D_rpl_test.rar with best regards, KarwosGSM. |
The Following User Says Thank You to kaisak For This Useful Post: |
02-24-2008, 01:50 | #3 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 612330 Status: Offline Thanks Meter: 35 | First test Nokia N70 => Typhoon Server v9.3+SX4+CRT, (c) 2004-2008 KarwosGSM -> Sending BB5 Certificates Restore Request... OK -> ASK Successfully Queued for Calculation. Credits left on account: 0 -> Disconnecting from Typhoon Server... OK Now waiting for RPL Reading ASK... ASK Read Success, Starting Server Transaction... -> Connecting to Typhoon Server... OK => Typhoon Server v9.3+SX4+CRT, (c) 2004-2008 KarwosGSM -> Sending BB5 Certificates Restore Request... OK -> Server error: ASK already found in queue, wait for calculation -> Disconnecting from Typhoon Server... OK then post result |
The Following User Says Thank You to Fock3 For This Useful Post: |
02-24-2008, 14:50 | #7 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | @all prices will be fixed tomorrow if any need test log can contact me through PM both multi-box and typhoon are supported so all what is needed to activate/upgrade account is typhoon/multibox sn |
02-26-2008, 17:25 | #12 (permalink) |
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | About timearound... from 5mins to 5 days! But... who knows, maybe when our Tucson access will be granted, realtime calc will be added ? who knows ops: |
24-02-2008 Nokia Tools v4.0I - full ASK/RPL cache, NPC/HWC/CCC/Variant CERT! | GSMtricks | Multi-Box | 13 | 03-07-2008 11:37 |
24-02-2008 Nokia Tools v4.0I - full ASK/RPL cache, NPC/HWC/CCC/Variant CERT! | GSMtricks | Multi-box LITE | 3 | 02-24-2008 19:23 |
New Nokia Tools v4.0D Update, Full SX4 Authorization added | karwos | Multi-Box | 33 | 02-03-2008 08:26 |
I'm looking for Nokia 3310 v4.18 full flash file. | kevin03 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-27-2001 02:03 |
Need Nokia 3210 v4.41 full flash with Russian lng | ***DIMER*** | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-14-2001 05:50 |
