2630 not charging after UNLOCK Anyone has problem with it? 3x 2630 after unlock give message this charger not supporter. Any solution? Cause it already eated my logs.. |
VERY STRANGE PROBLEM.....................I THINK ITS HARDWARE BUT WAIT FOR 911GT OR POST IN HIS NEW FORUM |
hi hi i had such probem before it was because of downgrading version of this phone . best regards daro |
Try To Upgrade .................... |
but if upgraded it will be locked any soluion to repair no charging problem. bcnboy |
I'm 100% shure that all these phones had this problem before :) Now solution next: Change battery without "A" at the end, or upgrade to 5.20 if U can without "CS" ;) sekmes jaunasis unlokeri ;) |
I have today downgraded to 4.21 and unlocked. After unlocking come charger not supporter problem. Befor downgrading the phone versie 4.90. versi 4.90 can not unlocked I got only unlock patch failed. Please solve this problem. |
4.90 unlock supported (not testd by me ) about battery: 4.90 supports new type of bateries : BL-4BA BATTERY FOR RM-298 A new battery BL-4BA has been introduced for RM-298. When using BL-4BA battery, MCU SW version 4.90 or later must be used, as older SW versions than 4.90 support only BL-4B battery. In service centres, please update the phone SW to version 4.90 or later, if the battery is changed from BL-4B to BL-4BA, otherwise the battery BL-4BA cannot be charged. |
I have tested versie 4.90, I get only error, I lost 10 log. Than I downgreded to 4.21 and unlocked. Before downgrading I tested the charger, That was no problem. After dawngrading I get cannot be charged problem. |
write full pm make full flash 1000/1000 tested by me |
1 Attachment(s) this is full pm for 2630 |
problem is from nokia not from patch unlock |
Problem is with all, v4.90 cant be unlocked so when you downgrade you get the problem of not charging,so its better if you fing a solution. |
i confirm that 4.90 is unlockable |
