Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 02-01-2008, 16:44   #1 (permalink)
Deimantas's Avatar
Member: 132757
2630 not charging after UNLOCK
Anyone has problem with it?
3x 2630 after unlock give message this charger not supporter.
Any solution? Cause it already eated my logs..
Old 02-01-2008, 16:59   #2 (permalink)
Member: 337837
Thanks Meter: 538
Exclamation
VERY STRANGE PROBLEM.....................I THINK ITS HARDWARE BUT WAIT FOR 911GT OR POST IN HIS NEW FORUM
Old 02-01-2008, 17:55   #3 (permalink)
Member: 858
hi
hi
i had such probem before it was because of downgrading version of this phone .
best regards
daro
Old 02-01-2008, 18:33   #4 (permalink)
Member: 337837
Thanks Meter: 538
Try To Upgrade ....................
Old 02-01-2008, 20:18   #5 (permalink)
bcnboy's Avatar
Member: 12126
Sonork: 1575463
Thanks Meter: 199
but if upgraded it will be locked any soluion to repair no charging problem.
bcnboy
Old 02-01-2008, 21:19   #6 (permalink)
ShadowmanX's Avatar
Member: 71526
Thanks Meter: 48
I'm 100% shure that all these phones had this problem before Now solution next: Change battery without "A" at the end, or upgrade to 5.20 if U can without "CS"
sekmes jaunasis unlokeri
Old 02-02-2008, 13:36   #7 (permalink)
Member: 10817
I have today downgraded to 4.21 and unlocked.
After unlocking come charger not supporter problem. Befor downgrading the phone versie 4.90.
versi 4.90 can not unlocked I got only unlock patch failed.
Please solve this problem.
Old 02-02-2008, 16:31   #8 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
4.90 unlock supported (not testd by me )
about battery: 4.90 supports new type of bateries :
BL-4BA BATTERY FOR RM-298
A new battery BL-4BA has been introduced for RM-298.
When using BL-4BA battery, MCU SW version 4.90 or later must be used, as
older SW versions than 4.90 support only BL-4B battery.
In service centres, please update the phone SW to version 4.90 or later,
if the battery is changed from BL-4B to BL-4BA, otherwise the battery
BL-4BA cannot be charged.
Old 02-02-2008, 18:20   #9 (permalink)
Member: 337837
Thanks Meter: 538
VERY WELL SAID SIR.....
Old 02-04-2008, 13:04   #10 (permalink)
Member: 10817
I have tested versie 4.90, I get only error, I lost 10 log.
Than I downgreded to 4.21 and unlocked. Before downgrading
I tested the charger, That was no problem. After dawngrading I get
cannot be charged problem.
Old 02-04-2008, 13:37   #11 (permalink)
Member: 61735
Thanks Meter: 8
write full pm
make full flash
1000/1000
tested by me
Old 02-04-2008, 13:42   #12 (permalink)
Member: 61735
Thanks Meter: 8
this is full pm for 2630
The Following User Says Thank You to deab2001 For This Useful Post:
Old 02-04-2008, 15:11   #13 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
problem is from nokia not from patch unlock
Old 02-04-2008, 20:45   #14 (permalink)
Member: 2800
Thanks Meter: 47
Problem is with all, v4.90 cant be unlocked so when you downgrade you get the problem of not charging,so its better if you fing a solution.
Old 02-04-2008, 20:49   #15 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
i confirm that 4.90 is unlockable
n80 not charging after unlock milad123 Universalbox 8 11-29-2008 13:02
o2 x7 not charging after unlock Zero23 FuriousGold 1 02-12-2007 11:25
K608 CID49 Not charging after unlock freewaycomms Cruiser Suite 1 05-13-2006 19:23
A800 not charging after unlock jeanfleur VLSI, Conexant, Skyworks and Old Models 1 01-15-2004 16:29
BE4¦138¦not¦charging¦after¦unlocking spidergsm Alcatel & TCL Old Models 2 12-03-2002 14:43
Page generated in 0.34797 seconds with 11 queries
