6131 ask2rpl but same problem FFFFFFFFFFFFFFFF plsssss help me sir i write rpl but same problem pls help me 911GT log here Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Send NPC Certificate Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101001101 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000353 PUBLIC_ID( RAP ): 0FA00005274B005850E054396DC091BE047372C8 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 191EC665DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 002F 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.96V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-115 (Mojito ) V 05.50/20-09-06/RM-115 (c) Nokia. IMEI: 35937400501**** Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! |
have same problem too ..... :( |
i have try to tx line 2 but same problem log here Phone is in: Local mode Model: RM-115 (Mojito ) V 05.50/20-09-06/RM-115 (c) Nokia. Production serial number MFJ527855 Product code 0534290 Module code 0202802 Basic production code 0526012 Flash code Order number Long production SN MCU SW V 05.50/20-09-06/RM-115/(c) Nokia. HW 4008 PCI RFIC 17211721 DSP dsp_mojito_05w46v31.1 PPM V 05.50/20-09-06/RM-115/(c) Nokia. /A Retu 32 Tahvo 53 Content Pack Content: india/V 03.70/31-05-06/RM-115/(c) Nokia. / IMEI: 3593740050***** WARNING: VPP pin is not connected, disabling VPP. IMEI: 359374005010745 Using Tx2 Data line. Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Send NPC Certificate Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101001101 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000353 PUBLIC_ID( RAP ): 0FA00005274B005850E054396DC091BE047372C8 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 191EC665DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 002F 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.92V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-115 (Mojito ) V 05.50/20-09-06/RM-115 (c) Nokia. IMEI: 3593740050***** Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! V 05.50/20-09-06/RM-115 (c) Nokia. IMEI: 3593740050***** Operator: FFFFFFFFFFFFFFFF Profile bits: FFFFFFFFFFFFFFFF Closed on GID1: 00101F Counters 0/10, 0/3 |
i have full erase and write rpl but same problem plsssssss help me sir 911gt log here Phone is in: Local mode Model: RM-115 (Mojito ) V 05.50/20-09-06/RM-115 (c) Nokia. Production serial number MFJ527855 Product code 0534290 Module code 0202802 Basic production code 0526012 Flash code Order number Long production SN MCU SW V 05.50/20-09-06/RM-115/(c) Nokia. HW 4008 PCI RFIC 17211721 DSP dsp_mojito_05w46v31.1 PPM V 05.50/20-09-06/RM-115/(c) Nokia. /A Retu 32 Tahvo 53 Content Pack Content: india/V 03.70/31-05-06/RM-115/(c) Nokia. / IMEI: 3593740050***** WARNING: VPP pin is not connected, disabling VPP. IMEI: 359374005010745 Using Tx2 Data line. Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Send NPC Certificate Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101001101 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000353 PUBLIC_ID( RAP ): 0FA00005274B005850E054396DC091BE047372C8 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 191EC665DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 002F 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.92V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-115 (Mojito ) V 05.50/20-09-06/RM-115 (c) Nokia. IMEI: 3593740050***** Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! V 05.50/20-09-06/RM-115 (c) Nokia. IMEI: 3593740050***** Operator: FFFFFFFFFFFFFFFF Profile bits: FFFFFFFFFFFFFFFF Closed on GID1: 00101F Counters 0/10, 0/3 VPP is DISABLED. Using Tx2 Data line. Processing File: BB5Erase_EE_16MBrap.bin Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. VPP is DISABLED. Using Tx2 Data line. Processing File: BB5Erase_EE_16MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00FF0000 - 00FFFFFF] Erase[0.06 MB]... Waiting response for 320 Sec...in 0.72s Flash[0.00 MB]...in 0.00s * * Processed file in 8.84 seconds Processing File: BB5Erase_16MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 00FFFFFF] Erase[16.00 MB]... Waiting response for 320 Sec...in 66.19s Flash[0.00 MB]...in 0.00s * * Processed file in 74.28 seconds * * * Phone flashing done in 1:37 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! VPP is DISABLED. Using Tx2 Data line. Processing File: BB5Erase_16MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 00FFFFFF] Erase[16.00 MB]... Waiting response for 320 Sec...in 3.88s Flash[0.00 MB]...in 0.00s * * Processed file in 11.94 seconds Processing File: BB5Erase_32MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 01FFFFFF] Erase[32.00 MB]... Waiting response for 320 Sec...in 78.72s Flash[0.00 MB]...in 0.00s * * Processed file in 86.77 seconds * * * Phone flashing done in 1:53 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! VPP is DISABLED. Using Tx2 Data line. Processing File: BB5Erase_32MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 01FFFFFF] Erase[32.00 MB]... Waiting response for 320 Sec...in 7.53s Flash[0.00 MB]...in 0.02s * * Processed file in 15.61 seconds Processing File: BB5Erase_EE_8MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [007F0000 - 007FFFFF] Erase[0.06 MB]... Waiting response for 320 Sec...in 0.23s Flash[0.00 MB]...in 0.00s * * Processed file in 8.30 seconds * * * Phone flashing done in 0:38 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! VPP is DISABLED. Using Tx2 Data line. Processing File: BB5Erase_EE_8MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [007F0000 - 007FFFFF] Erase[0.06 MB]... Waiting response for 320 Sec...in 0.22s Flash[0.00 MB]...in 0.02s * * Processed file in 8.30 seconds Processing File: BB5Erase_EE_16MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00FF0000 - 00FFFFFF] Erase[0.06 MB]... Waiting response for 320 Sec...in 0.23s Flash[0.00 MB]...in 0.00s * * Processed file in 8.30 seconds * * * Phone flashing done in 0:31 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! VPP is DISABLED. Using Tx2 Data line. Processing File: BB5Erase_EE_32MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01FF0000 - 01FFFFFF] Erase[0.06 MB]... Waiting response for 320 Sec...in 0.20s Flash[0.00 MB]...in 0.00s * * Processed file in 8.28 seconds Processing File: BB5Erase_EE_16MBrap.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00FF0000 - 00FFFFFF] Erase[0.06 MB]... Waiting response for 320 Sec...in 0.23s Flash[0.00 MB]...in 0.00s * * Processed file in 8.28 seconds * * * Phone flashing done in 0:31 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! VPP is DISABLED. Using Tx2 Data line. Processing File: rm115__05.50.mcusw Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000006BF] Erase RAP3 [000006C0 - 0001FFFF] Erase RAP3 [00020000 - 0007FFFF] Erase RAP3 [00080000 - 000DFFFF] Erase RAP3 [00100000 - 001FFFFF] Erase RAP3 [00200000 - 002DFFFF] Erase RAP3 [002E0000 - 00EDFFFF] Erase RAP3 [00EE0000 - 00EF7FFF] Erase RAP3 [00EF8000 - 00EFFFFF] Erase[14.88 MB]... Waiting response for 320 Sec...in 3.67s Flash[12.93 MB]...in 50.25s * * Processed file in 62.00 seconds Processing File: rm115__05.50.ppm_a Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00F00000 - 0145FFFF] Erase[5.38 MB]... Waiting response for 320 Sec...in 1.42s Flash[4.26 MB]...in 16.17s * * Processed file in 25.72 seconds * * * Phone flashing done in 1:42 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 05.50/20-09-06/RM-115 (c) Nokia. IMEI: 12345610654321? Factory Default Settings...OK |
Using Tx2 Data line. Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Send NPC Certificate Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101001101 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000353 PUBLIC_ID( RAP ): 0FA00005274B005850E054396DC091BE047372C8 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 191EC665DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 002F 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.95V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-115 (Mojito ) V 05.50/20-09-06/RM-115 (c) Nokia. IMEI: 3593740050***** Simlock send - FAILED! SuperDongle send - SUCCESSFULL!!! |
may be have a problem with the phone |
not have a phone problem unlock after problem plsssssssss help me sir 911gt |
how to shol this problem plssssssssssss help me 911GTTTTTTTTT |
i don't have an idea |
this is NOKIA server problem, not the phone! |
and this is possible too |
hello some 6131 proplem from rap ic br |
H E L L O 9 1 1 G T How To Shol This Big Problem I Need Help Plssssssss Sir My 40 Log Lost Plssssss Help 911gt And Softmobile |
Dont cry for ur Log they Wont REeturned as they DID to me.... My ASK was ok RPL calculated was BAD INvalid RPL......911GT said they were only doing this as a Part of nokia Service.... Not refunded my logs even prob was on their Side.....they can only See $$$$ Sign blinkin everywhere... |
