10-01-2007, 09:50 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | bb5 rpl problem!!! when i write the rpl it writes it ok , but imei still 123456.... and the self test shows security test fail i try to write the rpl 10 times with samse result what's wrong? Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg BOOT OK... Send NPC Certificate Phone Type: BB5 ------------------- SYSTEM ID Response: 7 blocks ------------- SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101003000 EM_ASIC_ID( RAP ): 00000232 EM_ASIC_ID( RAP ): 00000352 PUBLIC_ID( RAP ): 22C0000C9BBD0054E19B18CB87EDB2E3D1B7B4C8 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 273F6D55DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Samsung, 00EC 22FE 0000 0121 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ----------------- RPL Restore Certificate Status -------------------- RPL RAP3 Certificate sent SUCCESSFULLY Delay for 20 seconds... ============= Set FBus mode for info ============= VBat is 3.94V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-145 ( 6233) V 05.43/30-03-07/RM-145 (c) Nokia IMEI: 12345610654321? Simlock send - SUCCESSFULL!!! SuperDongle send - SUCCESSFULL!!! |
10-01-2007, 12:55 | #4 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | No.May be i write wrong. I want to say may be problem is in mcu like hardware not like software. I am sure you thing dc4 with bad imei but when you try to read ask in imei have a not only digits- on her need to change UEM to solve problem. I thing here have a same problem with erom into MCU RAP3G. |
10-01-2007, 18:28 | #9 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: www.GSM-IR.com
Member: 565354 Status: Offline Thanks Meter: 28 | Quote:
problem in write to data RAP3G and Region Data in MCU. B.R, Amin Soveiti ..::TOPNET_GSM::.. | |
Buggy MX . BB5 rpl problem . flashing problem. | blue_life1111 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 09-17-2009 15:45 |
bb5 rpl problem | www.dreammer | Universalbox | 1 | 03-10-2009 00:04 |
bb5 rpl problem | mrtysm | Universalbox | 1 | 05-15-2008 12:05 |
bb5 rpl problem | 468492DF | Universalbox | 1 | 02-13-2008 05:55 |
BB5 rpl problem! Can anybody help me? | Gsm-W | MT-BOX | 17 | 08-23-2007 12:05 |
