Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 12-08-2007, 23:28   #1 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,682
6280 cant read with phone info
i put in testmode but cant read the phone, i want to unlock, i try with mt-pro cable, also i try with fbus cable but cant read, cant flash.
phone work all ok with out sim card.
phone is locked...
any help 911GT? and all member
Old 12-09-2007, 06:42   #2 (permalink)
Cheater -Don't Deal with him-
Member: 78619
Thanks Meter: 297
dear just check its interface ic that is the problem,,,,,,,,,,,,,,,,
i faced one same problem and resolved through this ,,,u can find it in lower left on keypad side of the board.....
br khalid
Old 12-09-2007, 10:45   #3 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,682
br khalid
any photo pls????????????
thank you...
Old 12-09-2007, 12:53   #4 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,682
pleas 911GT any help.
phone now in test mode but
Phone is in: Phone is not responding, power on phone!
with diffrent cable i try, also dku.
maby from water problem ?
Old 12-09-2007, 13:41   #5 (permalink)
Super Moderator
Gsm Lab's Avatar
Member: 113928
Sonork: 100.111866
Thanks Meter: 1,838
clean phone dku jack .
Old 12-09-2007, 13:53   #6 (permalink)
Member: 337837
Thanks Meter: 538
phone is locked...
Try to clean its PCB or try with another F-bus cable then you can unlock it with MT BOX PRO OR LITE
Old 12-09-2007, 13:58   #7 (permalink)
stan1comm's Avatar
Member: 609952
Sonork: 100.1574492
Thanks Meter: 154
Use A Good Cable It,s Work 100%
Old 12-09-2007, 14:01   #8 (permalink)
Member: 337837
Thanks Meter: 538
reset security code or manually switch off automatic security keygaurd off your problem will be solved 100000000000000000%
Old 12-09-2007, 14:27   #9 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,682
Thank you all
my problem sloved....
br...
faruks82
the problem was in connector from water inside
Connect...
Resp:
o/0110/hello there
Login...
OK, available count
busy, waiting...
Server Response OK.
Connect TPs(D1)
V 06.43/30-03-07/RM-78 (c) Nokia
IMEI: 353227019763939
TPs OK
UNLOCK SUCCESSFULL
SUCCESSFULL
Operator: 8000000000000000
Profile bits: 2934000000000000
Open on Mcc Mnc: 29340F
Sim Status: Not locked
Old 12-09-2007, 20:19   #10 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
Ur Post Help Me....verry Good Discovery Bro...
please help.. S.E w205 after flash with SEtool../cant read imei, phone is dead residentdenuevo DreamBox 1 01-25-2010 15:05
Padfinder cant connect with phone luyanda PadFinder box 10 09-05-2009 15:24
cant read the phone pass word...error w850 CPF-Dongle 1 07-18-2009 16:00
cant read with fbus cable sunnny Universalbox 4 04-11-2009 19:29
6280 Cant Read Mmc Please Help gsm4sp Nokia Hardware & Hardware Repair 5 10-19-2006 20:28
Page generated in 0.18533 seconds with 9 queries
