07-18-2006, 15:06 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | 6630 dead after flash with MT Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase[37.34 MB]... Waiting response for 320 Sec...in 3.84s Flash[20.29 MB]...in 49.22s * * Processed file in 60.97 seconds Processing File: RM1_6.050308.v30 Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase[15.05 MB]... Waiting response for 320 Sec...in 1.91s Flash[3.47 MB]...in 11.17s * * Processed file in 21.03 seconds * * * Phone flashing done in 1:28 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! phone is dead now. what should i do?! |
07-18-2006, 16:14 | #3 (permalink) | |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | Quote:
here's log with lower speed flashing with mt Processing File: RM1_6.050308_B4.C0R Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase[37.34 MB]... Waiting response for 320 Sec...in 3.86s Flash[20.29 MB]... Downloaded news update from GriffinTeam. Switching to Online news tab in 64.44s * * Processed file in 76.58 seconds Processing File: RM1_6.050308.v30 Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase[15.05 MB]... Waiting response for 320 Sec...in 1.91s Flash[3.47 MB]...in 12.97s * * Processed file in 22.84 seconds * * * Phone flashing done in 1:46 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! no result! any other solution?!! | |
07-18-2006, 18:22 | #6 (permalink) | |
the phone works well, but sometimes restarts... VPP is DISABLED. no result | |
07-18-2006, 18:31 | #8 (permalink) | |
the phone original firmware was 6.030308 i upgraded it to 6.050308 u mean, lower version may help??! | |
07-18-2006, 19:09 | #10 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | try full erase handset and reflash it.......and some times restarting may cause bad RAP/flash ic if phone is used and some times fall on the ground byt in this case it will give error on flashing process or booting.....so i never faced problem like yours when flashing 6630 with MT.....check also PCB for water damage etc. WBR |
07-18-2006, 20:00 | #11 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Baltchik,Bulgaria Age: 50
Member: 47236 Status: Offline Thanks Meter: 58 | once bb5 phone is flashed higher version you cant donwgrade so your version is only 6.050308 from now on also there isnt erase flash option for bb5 phones(@tostefo) this erase files are for erase ADL loader in case that phone not booting here phone is booting very well i think in other cases i agree with tostefo try with other cable(are your cable remaded) 5.7k-6.1k on bsi br |
07-19-2006, 15:07 | #12 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | thanks friends for help but it's not my first time that i flash 6630 i did it before, without problem on all 6630 i have problem on this unit only. I tested my cable before, cable is ok I tried downgrade too, no result here is log: Processing File: RM1_5.050308_B4.C0R Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase[37.21 MB]... Waiting response for 320 Sec...in 3.73s Flash[20.25 MB]...in 48.49s * * Processed file in 60.17 seconds Processing File: RM1_5.050308.v30 Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase[15.05 MB]... Waiting response for 320 Sec...in 1.91s Flash[3.40 MB]...in 11.09s * * Processed file in 20.95 seconds * * * Phone flashing done in 1:27 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! |
07-31-2006, 15:15 | #13 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | today i flashed a working N70 with restarting problem. It now dead and here is the status. Processing File: RM84_50609201.C0 Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase RAP3 [00000000 - 0052AB0D] Erase RAP3 [006A0000 - 006BFFFF] Erase RAP3 [006DF000 - 006EFFFF] Erase RAP3 [00700000 - 007EFFFF] Erase APE [00000000 - 0000FFFF] Erase APE [00010000 - 0001FFFF] Erase APE [00020000 - 000203FF] Erase APE [00050000 - 03ECFFFF] Erase[68.92 MB]... Waiting response for 320 Sec...in 6.66s Flash[31.17 MB]...in 71.47s * * Processed file in 85.53 seconds Processing File: RM84_50609201.V08 Boot... rap3gv2_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_gbbm.fg Erase APE [01DE0000 - 028FFFFF] Erase APE [02900000 - 03ECFFFF] Erase[32.94 MB]... Waiting response for 320 Sec...in 3.56s Flash[7.97 MB]...in 22.53s * * Processed file in 33.34 seconds * * * Phone flashing done in 2: 5 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! what's problem?!! |
Nokia 6630 problem after flash with MT | rumm | MT-BOX | 3 | 03-01-2007 07:39 |
6630 Simlocked After Flashing With Mt-box!please Help! | KUBAT1 | MT-BOX | 6 | 06-22-2006 12:13 |
working 6630 dead after flashing in mt box | gsmservices | MT-BOX | 3 | 06-12-2006 17:00 |
6630 dead after flash with griffin solution | Pippox | Griffin | 9 | 07-13-2005 17:10 |
