06-12-2009, 02:50 | #139 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | i have 5300 with charger not supported problem.i did this solution and it worked.now the unit is charging but then now the unit turns off by it self without finishing to play a single song or music....what to do now? |
06-26-2009, 10:03 | #141 (permalink) |
No Life Poster Join Date: Jul 2006 Location: jambuser (sarod)_swaziland_uk Age: 40
Member: 317494 Status: Offline Sonork: 1000.1984 Thanks Meter: 187 | hi what about n73 my phone goes off automatically after 4 hour 5 hour i write ur pm phone goes on phone startup failed contact the retailer also there r no entreis off 42 62 also off no entries thoes who pm i have can u give me good pm or solution |
06-27-2009, 12:24 | #142 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Heaven city
Member: 242387 Status: Offline Sonork: landri Thanks Meter: 36 | contact service 6085 dear sir!!! plz could u help me plz? i have nokia 6085. "contact service" this is the log ; owering the phone... Reading... MCU SW version: V 06.00 28-11-07 RM-198 (c) Nokia. HW version: 1402 PCI version: RFIC version: 17211721 DSP version: pb06w14v50.1 PPM version: V 06.00 28-11-07 RM-198 (c) Nokia. C Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 06.00 28-11-07 RM-198 (c) Nokia. Production serial number: PMD608758 Product code: 0550853 Module code: Basic production code: 0531924 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358630015167465 IMEI spare to net: 3A 85 36 00 51 61 47 06 IMEI SV to net: 33 85 36 00 51 61 47 26 F4 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-198.ini Saved INI not found, loading INI list... WARNING! Update your Pkey to increase life counter! Setting local mode... Reading product code... Product Code: 0550853 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-198\ Searching for default location of ini... Checking path: \Products\RM-198\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-198\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! thnx u to aswer me. |
08-02-2009, 09:22 | #146 (permalink) |
No Life Poster Join Date: Aug 2006 Location: SPAIN-----UK
Member: 333439 Status: Offline Sonork: 100.1589101 Thanks Meter: 623 | yes but i have 3 moible imei ok but after restart but when i conect sx4 server then not conect ...........give option check phone secrity ............... u have any solution without rpl ............ |
5130 power off if you call final solution | tantan167 | Nokia Hardware & Hardware Repair | 34 | 12-18-2014 13:33 |
5530 power off if you call final solution | tantan167 | Nokia Base Band 5 ( BB-5 ) | 32 | 06-24-2012 13:15 |
Default BB5 power off after 20min,10min... FINAL SOLUTION | Jilani001 | Nokia Base Band 5 ( BB-5 ) | 8 | 01-20-2010 11:16 |
BB5 power off after (20min,10min...) FINAL SOLUTION | R@ZIB-BD | Nokia Base Band 5 ( BB-5 ) | 11 | 08-04-2009 04:19 |
Nokia 6600 power-off after 20mins or when installing applications.. | khem | Nokia Hardware & Hardware Repair | 7 | 11-10-2007 08:56 |
