Cnat use SX4 button - need help hi i have problem with charging 6280 in readed pm from phone i didnt find 309 field so i want to write new pm (w/o 308) but some fields need to SX4 activate i have credits on server so when push SX4: enter log/pass Connect... Login... IMEI: 357603005xxxxxx busy, waiting... and popup login menu again so i enter log/pass again: Connect... Login... busy, waiting... e/641/command execution error; Server error i have 30 credits but as i know this operation is free what im doing wrong please correct me Thanx B.R. |
read simlock state and you will see he is bad for me |
Operator: 8000000000000006 Profile bits: 2229900093172790 Sim Status: Not locked what bad? please explain |
also tried with another fully worked and unlocked 6280 - same error whats wrong? |
may be have problem with any NAT in your internet connection or any firewall |
no any firewalls or routers whats wrong with server? p.s. look pm and check my account for SX4 possibibity |
Check Your Pm And You Will See The Log All Is Ok |
just tried again Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 359382008xxxxxx busy, waiting... Connect... Login... busy, waiting... PMM Authorize FAILED phone is barnd new and unlocked via MT-Pro any idea??? btw is it important what MT sw version i use in this case i used v1.30beta and v1.29.1 |
finally i sorted out my pb maybe this will be usefull for other i dont use very oftenly GT server so to prevent any false using i didnt save log/pass in MT sw in this case SX4 authorisation dont work for me (all time i entered pass manually) but when i saved (save button) log/pass data all works fine maybe GT server have some delay sensititivy, i dont know anyway SX4 works like a charm!! p.s. after PM writing is usefull look in Warranty option to check Imei, it may be different just read new (real) imei by button and write Thanx for help and Big respect for GT B.R. |
I have problems with my 6288 after Full Erase. First there was SP area corrupted, but I repaired this problem by calculating ASK2RPL. But now this 6288 has the problem "Charger not supported", and I want to write PM and I have 30 logs remaining in my GT server account but SX4 is not working and MT-BOX returns this: CREDIT COUNT: 30; Failed to locate SX4 on PC. Connecting server Connect... Login... e/400/command execution error; Server error If I SPunlock this phone and afterwards I write PM (trying to repair that "Charger not supported" problem) excluding field 308 (Simlock field) is there a risk that the Phone Locks again?? Urgent attention needed please Don't reply if you never repaired those problems yourself. Thanks |
no you need to write only 135(309) field for a charging problem |
I have 25 credits left in my account. Can I use SX4 authorization with that amount of logs in my account when we all know that PM_AUTH doesn't consume logs. And can somebody upload good PM for this phone 6288? thanks in advance |
