external usb hub problems Note: When connected to PC through external HUB: On some cheap hubs, there are problems with communication serial and flashing. So if you are having problems with your MTBox, keep in mind it might be the HUB causing the problems. Good way to check if this is the problem is to connect box directly to your PC. |
