help dead w810i - k750i :mad: upgraded to new arm inside 2.8 now its killing phones flashed w810 gets to the end off dec file 100% then says fs error dead phone. went to up grade a k750 to w800 witch i have done lots of times wont even unlock now.i have upgraded the box using upgrade 3.5 also tried new arm inside 2.7 gives the same result think the problem is with upgrade tool 3.5 how can i solve this needs sorting quick need it for my shop please help :confused: :( |
W810 flash with latest version w810-AllInOne-r4db005. What is the CID and KEY on K750 which you want to upgrade to W800? |
:confused: hi have flashed w810 with that file with no luck the real problem is the k750 have worked on this phone before with no problems have used on two other phones old cid 24 with same result this problem has only arisen since the 2.8 update have used another mt on 2.7 without update and that works fine so the problem is with the online update have read other problems with this update on this forum .ihave had this box nearly a year so it is not a mistake on my part is there anyway i can reset the mt box as when i was using it with 2.7 it was fine now it wont work with that nither please help |
You can use also New ARM inside v2.7 with your box. Can you please post here what is the phone info by ??? button, file names which you write to phone. What is the phone status now , dead, live , blink or something else. |
phone has been done with my friends mt box that is working fine but he is still using 2.7 and has not has not updated with live updater 3.5 my box has killed 5 phones since update 3.5 and using new arm inside 2.8 3 k750s 1 w810 1 w800 all dead after failed unlocks and will not flash. will not load loader 2 then fails sorry i can not give exact details only phones have all been repaired with other box and returned to customers box has always worked fine till updated with 3.5 after that have had nothing but trouble .and now i don't want to try it with other phones in case it kills them ? |
this might be off some help just tried to flash a k600i on orange allready unlocked here is what is reads on ???? Starting the phone... PID:71 00 03 01 FF FF FF FF KEY:A1_DB2000_49_RED IMEI:35657200118850 CID (hex):0024 CID (dec):36 PAF:01 Mfrid0:89 Devid0:0D flash with rt2002 here is what it reads after fail Starting the phone... PID:71 00 03 01 FF FF FF FF Sending Loader1... Loader1 sent. IMEI:35657200118850 CID (hex):0024 CID (dec):36 PAF:01 Mfrid0:89 Devid0:0D Sending loader2 error:0002 dont want to run unlock in case it killes it this is what happens with every phone i try and flash i hope this helps as i am loosing money thanks ade :( |
Place the New arm inside v2.8 in same folder with v2.7 . The FLR folder does not exist in your software dir.Thats the problem. |
try to repair with ConfigurationRepair.rep |
sony erication800 phone short plz help me |
@smartcare Can you explain more clear what is the problem with your phone? |
help i kill my phone i went to flash it to w810i and now its dead help please any 1 |
