How did I lose a credit for same phone ! Unlocking a phone and first time could not connect. Second time it worked but it used up another credit. I had a long pm discussion with 911GT lsat week about this were I had lost a credit and he said it is impossible Now that the ppl that know me I am not a con artist and couple of logs is not the issue (well it is !!) but MT Team can you pls check this out for me as I have lost 2 credits already which is 40 Euros !!! Surely as this is the first time I have used MT Pro for 2 days you can check what phones I have unlocked ?? Same thing happened last week as well An honest answer is appreciated :) Model: RM-209 (7373) V 03.90/06-10-06/RM-209 (c) Nokia. Production serial number CEI2xxxxx Product code 0543810 Module code 0203099 Basic production code 0534038 Flash code Order number Long production SN MCU SW V 03.90/06-10-06/RM-209/(c) Nokia. HW 1002 PCI RFIC 17211721 DSP pb06w14v21 PPM V 03.90/06-10-06/RM-209/(c) Nokia. /C Retu 32 Tahvo 53 Content Pack Content: voda_payt_uk/V 03.90/06-10-06/RM-209/(c) Nokia. // IMEI: 3562910113xxxxx WARNING: VPP pin is not connected, disabling VPP. V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx Operator: 8000000000000000 Profile bits: 2341500000000000 Closed on Mcc Mnc: 23415F Counters 0/10, 0/3 Phone is in: Local mode Imei: 3562910113xxxxx W 03.90/06-10-06/RM-209/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\3562910113xxxxx.pm 134 : 0 0x1 bytes 134 : 1 0x2000 bytes 134 : 3 0x1 bytes 134 : 4 0x1 bytes 134 : 5 0xA bytes 134 : 6 0x1 bytes 134 : 7 0x1 bytes 134 : 8 0x1 bytes 134 : 9 0x28 bytes ================================= =================================== V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx Operator: 8000000000000000 Profile bits: 2341500000000000 Closed on Mcc Mnc: 23415F =================================== Using Account: bb5xxxxxxxxxxxxxxxxxxxxx Connect... Resp: o/0110/hello there Login... OK, available count 74; busy, waiting... Server Response OK. =================================== Connect TPs V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx (shortened) as post will be too long No communication with phone. Delaying 5 sec No communication with phone. Delaying 5 sec No communication with phone. Delaying 5 sec No communication with phone. Delaying 5 sec No communication with phone. Delaying 5 sec No communication with phone. Delaying 5 sec V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx Canceling detect on User request.... V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx Phone is in: Local mode Scanning files, please wait... Done Model: RM-209 (7373) V 03.90/06-10-06/RM-209 (c) Nokia. Production serial number CEI2xxxxx Product code 0543810 Module code 0203099 Basic production code 0534038 Flash code Order number Long production SN MCU SW V 03.90/06-10-06/RM-209/(c) Nokia. HW 1002 PCI RFIC 17211721 DSP pb06w14v21 PPM V 03.90/06-10-06/RM-209/(c) Nokia. /C Retu 32 Tahvo 53 Content Pack Content: voda_payt_uk/V 03.90/06-10-06/RM-209/(c) Nokia. // IMEI: 3562910113xxxxx WARNING: VPP pin is not connected, disabling VPP. V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx Operator: 8000000000000000 Profile bits: 2341500000000000 Closed on Mcc Mnc: 23415F Counters 0/10, 0/3 Phone is in: Local mode Imei: 3562910113xxxxx W 03.90/06-10-06/RM-209/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\3562910113xxxxx.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx Operator: 8000000000000000 Profile bits: 2341500000000000 Closed on Mcc Mnc: 23415F =================================== Using Account: bb5xxxxxxxxxxxxxxx Connect... Resp: o/0110/hello there Login... OK, available count 73; busy, waiting... Server Response OK. =================================== Connect TPs V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx TPs OK UNLOCK SUCCESSFULL SUCCESSFULL V 03.90/06-10-06/RM-209 (c) Nokia. IMEI: 3562910113xxxxx Operator: 8000000000000000 Profile bits: 2341500000000000 Open on Mcc Mnc: 23415F Sim Status: Not locked |
first 74 number is count from before second 73 is log counted for your phone bro check now count will be 73 and after press UNLOCK button will be 72 after next phone So GT didnt eat your logs ;) BR |
-When I started I had 74 -I could not unlock - so when I started the SAME phone again I had 73 How's that not losing ?? I check now and I only have 72 and I have only unlocked ONE phone :( |
as far as i know(is not sure..i only suppose that) the server has already build-in counter for each box and each imei. so...i think counter that is showed by mt box ..is not 100% the real one. the server keep the real counter..so you don't lose your credits. maybe i am wrong..not sure |
Would be very grateful if they physically checked what I have said in their server to confirm I am telling the truth :) |
counter shown at MT GUI is just the same from the server, so once again CHECK YOUR COUNTER BEFORE UNLOCK AND AFTER UNLOCK you will see that there isnt any logs `eating` you will be counting for every IMEI BR |
ok i think i give up ! |
in this log you post two counts bro 73 and 74 am i right you are tried second phone for 72 at last check your MT-box log file BR |
lost the will to live - forget it !! |
Yes this is a question from me too. I believe they track what you unlock by imei and you only burn a credit if they see an imei they haven't seen already. That's how it should work right? So if they take a credit off for an imei they have already seen that's just wrong. So the code on their side that has to remember which imei's they've previously seen has to be rock solid. That is they cannot have it burn a credit until they've recorded the imei they've seen otherwise if there's some kind of error you lost your credit but the server doesn't know it's seen this imei before and when it sees it again it will burn another credit. The act of updating the log counter and recording which imei they have seen has to be an automic operation. either all or nothing. Quote:
The way it's suppose to work is that it's only supposed to charge you a credit when it sees a new iemi. so the code that records which iemi's it's seen is important. The idea is that regardless of whether you succeed or fail the unlock you are charged the credit whenver the iemi is new. The idea being is that when you go back with the same phone again it won't charge the credit but the code that checks whether or not it's seen this iemi before has to be rock solid in order to not charge the credit for the same phone. The code isn't written to only take off the credit when it detects a successful unlock because if it was like that people would figure out a way to stop that "trip" from happening in order to avoid the credit charge. |
