Mt Box doesnīt power atc Hello, i have 3 mt-box nokia and 3 mt box lite... and all the three boxes canīt give power for any mobile. please any onde can solve my problem? |
connect the cable and press the power button manually. BR |
first you have to give some log to identify what problem you face...:) |
I have a similar problem, phone enter test mode 1 to 10 attempts, I use cable of 10 pins... The cable has a resistor 5.1K tomorrow chage for 7.5 how say here http://forum.gtibox.net/showthread.php?t=6 It is original from Ipmart :rolleyes:... Bye |
itīs not that. again, the problem is that mt-lite does NOT provide 4v in order to phone turn on. itīs not cable problem, itīs not attempt problem or anythinhg like that. pin1 on mt-box nokia does NOT have 4v, thatīs the issue. |
From where you bye this boxes ? Are they working before ? Try to contact GT911. or tell us more there .. I'm shure with reading much more this forum you will find solution . !!! ;) Don't worry . BR baboom Did you try with external power (Nokia charger) with usual F-bus cable ? (MT-box ) 1st be shure if MT-box is working well b4 connect MT-lite !!! ;) |
i have the same problem on mt-box, phone cant auto-enter in test or local mode and not power on ,i can use only easy cable whith battery .....!!!:confused: can support help us ???:) Quote:
use search for bb5 modified cables you find this :now this topic is over so many detalis still released |
whether all pins even and not damaged one... and also try with some 10 pin cables.....then also same means just return to your reseller... |
MT-Lite connector problem i change this with new and now never problem but one thing in new version some time software not open untill 2 or more than 2 time box reconnect its a bug or window/PC problem plz but when soft open works absolutely 100% ok |
thanks to all that tried to help, but again, you did NOT read my posts... "itīs not that. again, the problem is that mt-lite does NOT provide 4v in order to phone turn on. itīs not cable problem, itīs not attempt problem or anythinhg like that. pin1 on mt-box nokia does NOT have 4v, thatīs the issue." - it clearly states the problem is NOT faulty cable, so donīt bother saying anything about. Itīs not. - iīm not talking about "auto entering test mode" or anything like that. Iīm saying that pin1 DOES NOT have 4.10v like it was supposed to. - of course acp-12u or acp-12ub was connected. but again, ppl does not seem to understand that charger will only help to feed power to phone, but pin1 gotta have 4.10v all the time mt software is running, even when phone is not connected. - of course box used to work before. otherwise, weīd be looking for replacement, not for a hardware fix. - again, the problem is NOT with mt-lite, but with mt-nokia, which DOES NOT provide the usual 4.10v anymore - i work for the reseller, giving him the box wonīt make any change. anyway, all these boxes are out of warranty time, so they canīt be replaced. and each day, more ppl having same problem, and no solution Iīve seen worked. replacing the coils, r25, d8, c19 or even the arm atmel makes no change. - 2 more mt-nokia with same problem returned from our customers. it makes 6 mt-nokia half-dead, and a lot of other customers are looking for us in order to get their boxes repaired. @ baboom 911GT ignored all mails sent to him, so I donīt think he can/want to help. @ harim_1981 in order to say that pin1 does not have the 4.10v, of course pins were checked. itīs pointless to look at mt-lite connector, if power is not fed by mt-nokia. @ S I M seems like you have the same problem, so please donīt let this topic die until we find the cause. not powering phone, not entering test mode etc is only a symptom. @ adn****i box not opening at first time: problem with some kind of debugger being detected, or faulty smart-card reader. |
this problem is not for Private messages!! About that i dont answer to you on a PM!!I have more of 200 PM messages for things who is not for PM!!!! When box or adapter dont work correct and you cant solve this problem without open it ,and box or adapter is in warranty yhen return to reseller for a change |
