MTB_NK_v1.29.5 FLASH 6230i ERROR 2 Attachment(s) ?????????????????????????????????? Use JAF OK |
disable vpp and then try again it will help you |
Change the ppm and content file,you select the E version but try the M version. Example you have ppm file RM_72_73_110E.03.88R,change the E in M and also do this for the content file |
Also check box Disable VPP. |
@Remco is right Mate! try his solution..... |
Same problem with me any body help me |
Post screen shot here. |
here is the screenshot: MTBOX: 000xxxxxxx - Nokia Flash/Repair v1.29.5 Box: CR V 1.001 256 Code: NK V 1.001 1044 SN: 000xxxxxx Nokia Unlimited: 855 times started SonyEricsson Trial: 10 left, each max 15min VPP is DISABLED. Processing File: rm72_73_11003.880 Boot... ASIC ID: 1052 TIKU BT2 te_2nd.fia te_amd.fia 841D7E5B5D35DBE281F1DB8F80DA Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Unkown, FDFF FDFF FFFF 0000, 0 04000000: NotUsed, 0000 0100 0000 0000, 0 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Erase[15.56 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 009FFFFF] erasing region [00A00000 to 00B3FFFF] erasing region [00B60000 to 00FAFFFF] in 141.38s Flash[10.14 MB]...in 53.55s * * Processed file in 205.50 seconds Processing File: rm72_73_110E_03.88.ucp_C Low level format...OK Boot... ASIC ID: 1052 TIKU BT2 te_2nd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC 22F8 0000 0011, 10 02000000: Unkown, FDFF FDFF FFFF 0000, 0 04000000: NotUsed, 0000 0100 0000 0000, 0 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 %%%%%%%% ERROR BOOTING: WBR |
Mate! try to chang your file "rm72_73_110E_03.88.ucp_C" with "rm72_73_110M_03.88.ucp_C" and also change PPM file.... |
and try to set slow methode!DCT4 slow! |
